Polar Lights 1/350 scale K'T'inga lighting kit p/review
Re: Polar Lights 1/350 scale K'T'inga lighting kit p/review
Post by Steam235 » Mon Oct 15, 2018 4:13 am
My Final thoughts on the Lighting Kit for the 1/350 scale K'T'inga model kit.
To cut to the chase. This is a great lighting kit.
You won't need to solder anything, you won't need to worry about resistors, volts or circuits. It's entirely plug and play. every LED strand is labeled clearly and fits on to the circuit board.
I loved being able to use an off the shelf product to light the kit rather than building my own lighting, the only other kit I've built that had an official lighting kit was the Bandai PG Falcon. This lighting kit was actually better than the Bandai PG lighting kit. The Bandai lighting kit was similar in design, but actually inaccurate in what it lit. (the landing gear doesn't have spot lights on the falcon.
This kit is very accurate to the filming model it replicates the engines, weapons, collision lights and windows. it replicates the flood lights that shine on the hull and has blinking lights on the neck and bottom.
Perhaps the most accurate part is that the lighting is in scale, the windows are not very bright, the strobes, flood lights engines and weapons are.
I was very impressed with the light piping used in the nacelles, and the use of PE to get the right shapes.
There were only a few things I would consider cons. I think the battery compartment is very crowded. I wish the circuit board was enclosed. You need to be careful and make sure not to damage any of the solders (the instructions call this out several times so I think even novices will know to be careful.
Something I wish I had realized; not all of the red parts should be used. Some are just included in red because of where they were on the sprue.
Something I wish I had done differently. I would have enlarged the window openings in the plastic even more than I did. I didn't open them too much and I think that it limits the viewing angle for the lights. Those lights are just so small and narrow they don't let much light through. The wider you can make those holes in the plastic parts the wider your viewing angle will be. I hope this diagram shows what I mean. I fell that on mine you have to be looking fairly dead on to see the window lights properly.
Overall this kit will let you light the model easily and accurately, and that's what it's all about.
kingsnake1
Post by kingsnake1 » Sun Dec 09, 2018 3:45 pm
My first post here ever...
My concern with the lighting kit is that it will make the bulb part of the model appear hollow if lighted according to directions. I see some mention of scuffing the clear plastic part to diffuse light, but...will this really help?
Father Cool
Post by Father Cool » Mon Dec 10, 2018 10:56 pm
Yes scuffing clear plastic works great as a diffuser however it does need to be done uniformly and with very fine sandpaper or else the scruffs can show.
Scuffing small things is comparatively easy though, scuffing this baby was as hard as hell as any slight difference in scuff level ended up with uneven lighting across the deflector. It was akin to polishing mirrors for telescopes haha, ok perhaps not that bad!!
Viz
Post by Viz » Thu Dec 13, 2018 7:38 pm
Love your build. Thanks for taking the time to post this in such detailed pics and giving us such a good guide to the lighting.
This kit has not been realeased in the UK yet. I have 3 of these kits including 3 lighting kits bought and paid for . Still waiting for them to arrive. Needless to say, reading your posts, I am super excited.
Post by Tesral » Fri Dec 14, 2018 3:22 pm
Klingon kits are not released! They escape leaving a trial of blood, and bodies behind them!
Post by Steam235 » Sat Dec 15, 2018 5:00 am
You'll really like the kit! Are you going to make all three the same? Or do you have different plans for each?
Viz
Post by Viz » Sat Dec 15, 2018 10:03 am
I am planning to use 3 kits on one base ( a Starfield with a V'ger Cloud backdrop. The base and the backdrop is to be lit as well as the ships.
Post by Tesral » Mon Dec 17, 2018 3:49 pm
That will be huge. A single one is too foot long.
Viz
Post by Viz » Sat Dec 22, 2018 11:00 pm
Yes it is going to be very big. Crazy big. But onece I get an idea in my head......
I am planning to light up the base and backdrop too.
