Spindrift from Land of the Giants by Polar Lights
Re: Spindrift from Land of the Giants by Polar Lights
Post by MEATLOAFr » Tue Apr 10, 2018 4:54 am
MSgtUSAFRet wrote:
Well........
Poop.
Post by trekriffic » Thu Apr 12, 2018 10:28 pm
Soooooo.... anyway, here's a photo of the funk on the windows:
ImageJunk by trekriffic, on Flickr
I was not going to stand for that so...
I removed the clear window plastic using a scribing tool and Tamiya mini-photo-etch saws:
ImageWindow Removal by trekriffic, on Flickr
With the windows out I decided to take some photos of the cabin with the lights on:
ImagePilot's cabin roof by trekriffic, on Flickr
ImagePilot's Cabin Lit without Windows by trekriffic, on Flickr
Making replacement windows using Evergreen .015 clear styrene sheet. Have to be careful not to scratch them during installation:
ImageMaking New Windows by trekriffic, on Flickr
Stay tuned!
Post by trekriffic » Sat Apr 14, 2018 5:10 pm
Update for today...
I used this technique in my Apollo 11 Eagle build to separate the two glass (?) panels in the upper docking window port of the LEM. Only that time I used red adhesive backed vinyl strips. I cut thin strips of black sticky backed vinyl thin enough to fit along the back edge of the bow window rims, leaving enough room for the clear styrene window plastic to fit inside the rim up against the vinyl gasket:
ImageAdhesive Backed Vinyl Paper Makes Gaskets by trekriffic, on Flickr
Starboard window install...
The inside of the frame was coated with Elmer's clear craft glue. Then I removed the tape on the backside of the clear plastic pane and cleaned it with alcohol and a clean cotton shirt. I left the masking tape in place on the outside of the window to protect during installation:
ImageStarboard Window Installed by trekriffic, on Flickr
Satisfied it was clean I gently placed the window pane into the frame; then over a few minutes I adjusted its position inside the rim. I also gently held down the edges as the glue dried:
ImageStarboard Window In Place by trekriffic, on Flickr
Both bow windows glued in place:
ImageBoth Bow Windows Glued In Place by trekriffic, on Flickr
Masks removed...
I'll lay in some more of the clear craft glue. That stuff is great for windows being water based and clear:
ImageMask Removal by trekriffic, on Flickr
Need to remask the bow windows after the putty dries around the frames then she'll get a shot of black to hide any remaining light leaks., then grey primer, followed by white primer, followed by yellow, followed by orange. Think I'll airbrush all of these layers to avoid many thick layers from a rattle can:
ImageSpindrift So Far by trekriffic, on Flickr
Dorsal fin detail...
I was happy with how this turned out; extending the sidewalls of the channel the fin slides into so it continues on in a smooth line where the hull breaks:
ImageDorsal Fin Detail by trekriffic, on Flickr
One more gratuitous profile shot...
Oh God... I still, need to finish the stand...
Post by trekriffic » Wed Jun 13, 2018 4:57 pm
Well almost two months since my last post and not much progress to report.
Most of my time has been devoted to coordinating improvements to my house.
So dealing with a lot of upheaval with new flooring, new countertops in the kitchen and baths,
and new interior wall paint.
Thankfully we're in the home stretch so hope to see a return to normalcy in the near future.
In the meantime here are the last set of pics showing the Spindrift in various stages of priming,
puttying and sanding, more priming, and more sanding, she's got a coat of white primer on her now.
Anyway, here goes...
I masked the windows with Tamiya masking tape and brushed on some Future to seal around
the edges to keep paint from bleeding under the tape:
Bow Windows by trekriffic, on Flickr
I brushed on some liquid Tamiya grey primer then sanded smooth again:
More Primer by trekriffic, on Flickr
The grills and window frames got another brushing with Tamiya primer after puttying:
Brush Primed Windows by trekriffic, on Flickr
She got a shot of flat black Testors enamel for light blocking:
Black Spindrift by trekriffic, on Flickr
Testors silver points out any remaining flaws that need to be addressed:
Silver Spindrift by trekriffic, on Flickr
Here she is just after spraying with Testors matte white enamel.
After this she gets a coat of yellow followed by Italian red:
White Spindrift by trekriffic, on Flickr
Closeup of Bow by trekriffic, on Flickr
More to come... soon I hope...
Post by kobayashimaru » Wed Jun 13, 2018 8:29 pm
it's the real deal,
at this point, if you pulled a Mr Burns "Hop in!"
(with the popsicle plane hehe)
I'd believe it, look at it go hehe
Post by MEATLOAFr » Thu Jun 14, 2018 2:24 am
it's the real deal,
Post by Tesral » Thu Jun 14, 2018 4:20 am
1/1 house model. I get that.
Post by trekriffic » Sun Oct 21, 2018 11:00 pm
Well the airbrush booth arrived a few days early so I assembled it this morning:
New Airbrush Booth by trekriffic, on Flickr
This is a portable booth and folds up into a case which I can't foresee me doing anytime soon so after unfolding it I snapped the LED bars into place and lined the interior surfaces with heavy bond watercolor paper which I taped to the walls and ceiling. Should make cleanup a lot easier:
Airbrush Booth Front by trekriffic, on Flickr
I gave the Spindrift a quick going over with canned air and, now satisfied it was free of dust, placed it onto the painting stage. I also got a set of these yellow triangular blocks to lift the model up:
The Spindrift Ready for Yellow Coat by trekriffic, on Flickr
Here she is after spraying the upper hull with Testors Flat Yellow. I'll give it a day to dry before spraying the underside:
Yellow Spindrift by trekriffic, on Flickr
After the yellow coats have dried and been lightly sanded she'll get her final coats of Italian Red.
Thanks for reading and sticking with me for all these months everyone!
Post by Tesral » Mon Oct 22, 2018 5:20 pm
Woot! She is back!
WarpNein
Post by WarpNein » Tue Oct 23, 2018 12:40 am
ARISE, THREAD
Wow, a year in now. This has been a spectacular build. Can't wait to see the finished product.
Return to “Off Topic”
