Calling all professional kitbashers
shiftdel
Re: Calling all professional kitbashers
Post by shiftdel » Sun Feb 11, 2018 9:22 pm
I am not a professional kitbasher, but I would like to give my 2 cents...
this last configuration is the one I liked most, the wings position seems right, and the general look is very Klingonish. I think the right nacelle also seems more Klingon.
Something that may work would be to cut the tips of the wings and glue them as an extension after the nacelles, not sure if I could explain it right... :(
Post by el gato » Mon Feb 12, 2018 1:19 am
shiftdel wrote:Something that may work would be to cut the tips of the wings and glue them as an extension after the nacelles, not sure if I could explain it right... :(
You did, I get what you're saying. No one seems to be a fan of those pointy things
NoKhando
Post by NoKhando » Mon Feb 12, 2018 4:34 pm
I think those pointy bits are Ok .
What those wings need is a bit of anhedral and dihedral to liven them up . Think Junkers 87 Stuka "W" wings with those pointy bits angled upwards . Maybe the original warp drives too . The new ones look like overkill .
Post by RogueWolf » Sat Feb 17, 2018 8:27 pm
Keep the head, loose the triangle 'bridge' piece. keep the negvar part for the main hull. Turn the wings foreword again (like the first pic) and trim/reshape them to the bat'leth like shape. That way she'll have outer wing tips and inner wing tips for disruptor mounts!!!
Sword of Kahless Class!!
Post by el gato » Mon Feb 19, 2018 8:00 am
OK now I'm really torn. I liked the first configuration because it was evocative of a bat'leth, like you said. But once mophius pointed out a way to make it look closer to the D-7 I started liking the wings swept back. Decisions decisions
Post by RogueWolf » Mon Feb 19, 2018 3:02 pm
Do what you like, not what others like. If you are a fan of the D7 and want to pay homage to it, reflect that in your design. If you like the bat'leth, make it a point of coming back later to work on a different kitbash or even scratch build to pay homage to the bat'leth.
I suggest you try to keep focussed on the build at hand and follow that paths that speak the most to you - you will have a better kitbashing experience and will look forward to your next foray into the 'bashing way of life!
#1 rule - have fun
Post by el gato » Mon Feb 19, 2018 5:17 pm
RogueWolf wrote:#1 rule - have fun
Hmmm, there's my problem right there :doh:
:lol:
Post by Tesral » Mon Feb 19, 2018 5:43 pm
#2 rule: You cannot do scratch building wrong.
