Once
Once
Post by Tesral » Sat Jul 29, 2017 7:38 am
Yes you can use an insulin syringe to place CA glue, once.
I'm glad I saved a box of those things.
Re: Once
Post by MEATLOAFr » Sun Jul 30, 2017 3:18 am
exactly - I have some old single use use oral ones for mixing paints that I got from work
Re: Once
Post by el gato » Wed Oct 04, 2017 3:23 pm
One drop or multiple applications within one session?
Re: Once
Post by trekriffic » Wed Oct 04, 2017 3:36 pm
As fast as CA dries I doubt the needle would stay open for more than a few seconds. I have some empty single dose syringes from when my deceased father-in-law had to inject an anti-clotting drug into his legs.
Must be 20 or 30 of them in this plastic container. The needles are of a very small gauge. I've only used them a few times for injecting resin into small window openings or to apply CA along a hard to reach joint. They clog easily and are only good for a single use.
Greyryder
Re: Once
Post by Greyryder » Thu Oct 05, 2017 2:41 am
Has anyone tried the small applicators, like Micro Mark sells?
https://www.micromark.com/Micro-Glue-Applicator_2
https://www.micromark.com/Mini-Loop-Applicator
Seems like they could at least be cleaned, afterward.
Re: Once
Post by Tesral » Fri Oct 06, 2017 4:09 am
I have a single wire applicator that I sometimes use, nothing to clog and it will hold a single drop of glue. Most of the time I use micro brushes that I buy by the hundred.
I still hate the stuff.
