STAR TREK Size Chart
FLEETYARD
Re: STAR TREK Size Chart
Post by FLEETYARD » Fri Feb 09, 2018 3:18 pm
This is my calculation for the USS Discovery:
http://fleetyard.blogspot.de/2018/02/th ... -star.html
FLEETYARD
Post by FLEETYARD » Fri Feb 09, 2018 3:21 pm
el gato wrote:...Question: I understand that the Discovery's dimensions were finally revealed through the Eaglemoss mini. Did the same happen with the Walker Class? And, if so, how do they measure to your calculations?
For my calculations of the size of the ST Discovery spaceships, I used the size of Commander Michael Burnham. I used the bridge to calculate how tall the decks are.
Post by el gato » Sat Feb 10, 2018 12:25 am
Thanks!
Mot
Post by Mot » Sun Feb 11, 2018 4:52 am
Hi to all, @FLEETYARD Hi, I love seeing schematics and size comparisons, They give a real sense of solidity and scale and complexity to otherwise ephemeral images onscreen.
Do you ever use real-world sizes - such as an actors published height on their homepage - to determine the dimensions of onscreen sets? I find it laudable that you provide such detailed comparisons. When I first got hold of the Sternbach E-D blueprints I was mesmerised for a week, The Jeffries plans... well, nuff said.
I'm not sure if you have said in this thread (or I have just missed it), but what criteria do you employ to reconcile discrepencies between what's seen onscreen, the published (canon?) information, and other written works, such as the Writer's Technical Manual and interviews with the creators of the shows?
Many thanks for all your work.
Mot :wavingyellow: (Not waving, dusting my shelves)
FLEETYARD
Post by FLEETYARD » Sat Mar 03, 2018 9:20 am
My calculation for the new JJAbrams Enterprise from Into Darkness:
http://fleetyard.blogspot.de/2018/03/si ... elvin.html
FLEETYARD
Post by FLEETYARD » Sat Mar 10, 2018 8:13 pm
FLEETYARD
Post by FLEETYARD » Sun Jul 15, 2018 11:50 am
Here's a recalculation of the size for the Oberth class:
http://fleetyard.blogspot.com/2018/07/t ... issom.html
Post by kobayashimaru » Mon Jul 16, 2018 12:20 am
@fleetyard
does that revise the Oberth's overall length and beam as an increase or decrease to the overall dimensions?
EDIT:
so, it seems they've used the Jeffries tube as a stadia for the connectors to the fuselage-section,
therefore, it's a larger starship?
The Oberth and K BoP are highly prone to 'magic scaling syndrome".
though, I wouldn't mind the Oberth being that fraction larger, especially if the TOS variant is larger, and the smaller size is the TNG production run epoch.
Post by TrekMD » Mon Jul 16, 2018 2:08 am
Interesting. The guys from TrekYards did a video about this a few weeks ago and came up with several potential sizes also.
Post by Tesral » Mon Jul 16, 2018 7:10 am
It still would be better off with a single central pylon.
