1000 scale Orville from Starcraft Models
- Starcraft Models
- Lemme At Em Lieutenant
I would like to introduce my latest kit; the 1000 scale Orville and it's 13.5" long. This kit is designed to be lighted. the primary hull is two pieces that are hollowed out. They are cast in clear for easy lighting. The rings are solid, however they have trenched cut out for lights. There are clear detailed covers that fit easily over the trenches. All the rings come pre- wired with the wire cast inside the resin. The middle ring is long and thin, so I also cast a brass tube inside to prevent sagging. The lower ring is also pre-wired for the clear bussard collectors. The shutlle bay may be built opened or closed, there is a separate door piece. Since the walls ans ceiling are clear, the light form the hull will create back lighting to the shuttle bay. I even created wallpaper decals for the shuttle walls to add a realistic lighted shuttle bay! I am thinking about making a shuttle, but are that scale it would be TINY. It would only be .096" by .302" that's 5/16".
- Attachments
- IMG_2447.jpg (71.98 KiB) Viewed 6668 times
- The seam closes up much better than show in this picture
- IMG_2446.jpg (85.38 KiB) Viewed 6668 times
- IMG_2445.jpg (73.88 KiB) Viewed 6668 times
- IMG_2444.jpg (99.51 KiB) Viewed 6668 times
- IMG_2440.jpg (98.41 KiB) Viewed 6668 times
- IMG_2439.jpg (80.13 KiB) Viewed 6668 times
- IMG_2438.jpg (96.22 KiB) Viewed 6668 times
- IMG_2433.jpg (83.45 KiB) Viewed 6668 times
- IMG_2432.jpg (66.8 KiB) Viewed 6668 times
- IMG_2431.jpg (66.19 KiB) Viewed 6668 times
- IMG_2430.jpg (89.25 KiB) Viewed 6668 times
- IMG_2429.jpg (80.77 KiB) Viewed 6668 times
- The primary hull is now hollowed out.
- IMG_2428.jpg (73.06 KiB) Viewed 6668 times
Re: 1000 scale Orville from Starcraft Models
How much will the Orville cost ?
Keith
Keith
- Starcraft Models
This was one of the most challenging kits I've ever made, all those complex curves. I will need to ask $170.00
Put me down for one please.Thank you.
Keith
Keith
- TrekMD
- Head of Starfleet Medical
Wow, that looks great!
- Griffworks
- Can-Do Captain
Damn nice, Dennis!Starcraft Models wrote: ↑Sat Jul 07, 2018 2:10 pm This was one of the most challenging kits I've ever made, all those complex curves. I will need to ask $170.00
Would you consider casting them w/o the wiring for those who don't want to light their models?
My Flickr Albums
My Flickr Albums
- Charismatic Commander
That came out beautifully.
- ProfArturo
- Can-Do Captain
That looks fantastic!
- Griffworks
- Can-Do Captain
My Flickr Albums
My Flickr Albums
- Starcraft Models
I sure can, and cast the entire kit in opaque resin.
