Federation Standard Containers
Post by Tesral » Tue Jan 02, 2018 5:35 am
Federation Standard Containers are usually represented in 1/2500 as 1/2". That would be wrong. The FJ manual said they are 40 meter across, that scales to 0.629". Or 5/8"
Aluminum tubing is available in that size. This must be explored.
jkb-1
Re: Federation Standard Containers
Post by jkb-1 » Tue Jan 02, 2018 4:30 pm
Wooden dowels, too. Easier to work with, although I've never been able to sand the ends into the proper shape. They take a lot of primer or paint to cover the grain, and they show up any dings they get.
Hossfly72
Post by Hossfly72 » Tue Jan 02, 2018 5:24 pm
5/8 osd PVC or Pex pipe.. filled with putty and the ends sanded to shape..
Post by trekriffic » Tue Jan 02, 2018 7:09 pm
I like the wooden dowel idea although PVC pipe sounds good too. For the ends you maybe could bond a pair of these 1/2" diameter acrylic half spheres:
https://www.usplastic.com/catalog/item. ... FoQAvD_BwE
Post by trekriffic » Tue Jan 02, 2018 7:10 pm
They also come in 5/8" diameter.
Post by el gato » Tue Jan 02, 2018 7:57 pm
jkb-1 wrote:Wooden dowels, too. Easier to work with, although I've never been able to sand the ends into the proper shape. They take a lot of primer or paint to cover the grain, and they show up any dings they get.
Dings in wood are easy to fix with a little water and some sanding
Jason Abbadon
Post by Jason Abbadon » Wed Jan 03, 2018 8:06 am
For TMP era containers, I've used Super Glue tubes.
Vahmp
Post by Vahmp » Wed Jan 03, 2018 11:04 pm
trekriffic wrote:I like the wooden dowel idea although PVC pipe sounds good too. For the ends you maybe could bond a pair of these 1/2" diameter acrylic half spheres:
The Half spheres would be TOO round for end caps of the containers.
Laterz...
Vahmp
Vahmp
Post by Vahmp » Wed Jan 03, 2018 11:08 pm
I have a file on just about every single drawing of ST TOS (and TMP, I think) containers made.
Lots of container and decal ideas for containers.
Laterz...
Vahmp
NoKhando
Post by NoKhando » Sat Jan 06, 2018 8:22 am
5/8" ? That's 16 millimetre in real money isn't it .
Try searching for 16mm plastic (polystyrene) test tubes . 8-)
