50x50=2500, 2 Round 2 (pic heavy)
Re: 50x50=2500, 2 (pic heavy)
Post by Tesral » Fri Jan 05, 2018 1:41 pm
Jason Abbadon wrote:For those bases, get Museum Wax!
Seriously, it's amazing, non-toxic and doesn't hurt anything.
I use fun tac the same way. It is meant for mounting posters to walls. It also more or less keeps the cats from knocking things over. General Grevious notwithstanding.
NoKhando
Post by NoKhando » Fri Jan 05, 2018 2:39 pm
You stick it on the cats ? :o
Does it work on kids ? :thinking:
Post by Tesral » Fri Jan 05, 2018 5:00 pm
NoKhando wrote:You stick it on the cats ? :o
Too fuzzy, it doesn't stick,
NoKhando wrote:Does it work on kids ? :thinking:
I suppose if you have enough of it. I've never tried it myself.
Jason Abbadon
Post by Jason Abbadon » Fri Jan 05, 2018 8:28 pm
That's like the lint roller I use to get my clothes (maybe) clean of cat hair.
I tried rolling it on to the cats themselves but they just lean into it.
Anyway, I need to order some more museum wax for my 1:2256 SW builds. Really hot a fleet going!
Post by slawton » Mon Jan 08, 2018 2:41 am
Here's some work in progress (top ones finished, bottom ones needing more work) of the bases/badges/artwork:
trek3159 wrote:Wow, would love to get a copy of about six of those to use to make bases out of....look really nice! I got some off of ebay last year to make bases out of but haven't figured out how to deepen them enough to hold anything. They are about 1/8 inch thick.
The four on the left are about 1/8 inch thick and come included with analogous Star Trek figures. Since they are plastic and hollow, they are pretty lightweight. The 2 on the top right are 3/8 inch thick and are more substantial. The rest are fairly thin (1/4 or less). They may be able to be thickened and casted.
Alternatively, you may also want to look into these:
These are 1, 2 & 3 inch bases from the old DQ. The smallest ones are about 1/4 inch thick and the largest are 3/8, so they are pretty solid and heavy. I'm guessing he may still have a few left over.
Post by Del » Mon Jan 08, 2018 3:55 am
slawton wrote:Alternatively, you may also want to look into these:
No, he doesn't have any left over. However, he had them made by Matt at LaserFire Creations, so you could ask him for a quote on a bunch. http://www.laserfirecreations.com
Post by slawton » Sat Jan 20, 2018 6:50 pm
Well I wrapped up the badges/pins/bases/artwork. Here's the Federation stuff:
And the aliens:
Post by slawton » Sun Apr 08, 2018 5:11 pm
With all these Enterprise B & Excelsior posts, I decided to get started on my Excelsior "un-refit":
The left side shows the Enterprise B removed bits with the unchanged on the right. Removed the extra fins on the front/back top of the nacelle, the bulge from the secondary hull and the extra bits on the top/bottom of the saucer.
Post by el gato » Sun Apr 08, 2018 5:35 pm
I plan on doing that but backfilling the to-be-removed bits with Aves. That way the area is already "reinforced" when I cut & sand them off
Post by Tesral » Sun Apr 08, 2018 11:47 pm
el gato wrote:I plan on doing that but backfilling the to-be-removed bits with Aves. That way the area is already "reinforced" when I cut & sand them off
Idea noted and swiped.
