1/2500 Klingon D7
1/2500 Klingon D7
Post by mophius » Sun Jan 15, 2017 10:28 am
Also made a start on this one last night.
Here it is on the sprue.
And cut off the sprue.
I noticed that one of the nacelles had not formed properly on the aft face. I started to file away at it but was not able to make a decent job of it. So I decided to file it completely flat which doesn't look too bad. Mafe the other nacelle the same and may add something putty-wise tomorrow.
I then washed all the parts and left to dry. More work on this later.
Re: 1/2500 Klingon D7
Post by mophius » Mon Jan 16, 2017 11:29 pm
The liquid green went on so well on the Romulan Bird of Prey that I decided to give the D7 a couple of coats around the hull and neck gaps. Also put some around the necelle joins too, just me being picky I suppose.
Post by mophius » Thu Jan 19, 2017 6:30 pm
Took this one to work too and primered.
Also has the same state of play as the RBOP.
Post by mophius » Sat Feb 18, 2017 11:44 pm
Made some progress tonight. Finally.
The green is a stock Humbrol Acrylic but the grey I had to mix. Just the nacelles and a few touch-ups to do now.
I hope it dries well.
Post by mophius » Sun Feb 19, 2017 8:05 pm
Ready for glosscoat before decals
Post by mophius » Mon Feb 20, 2017 11:41 pm
Decals are on.
Post by trekriffic » Tue Feb 21, 2017 5:57 pm
Nice work. I have the Johnny Lightning D7 myself. I thinks it's the same size.
Post by mophius » Tue Feb 21, 2017 7:21 pm
Thanks.
I put a coat of gloss lacquer on today at work and caught the underside front of the neck. I will have to rub that down gently before applying a matt laqueur to take some of that sheen away. Also have two parts on the underside of the main body that are, for some reason, down to the undercoat. Both are on an edge so it has sat on something. Wonder if I can touch those in before that too.
Post by trekriffic » Tue Feb 21, 2017 9:38 pm
mophius wrote:Thanks.
Did you lay it down to spray the clearcoat? It's always better to suspend it somehow. For these small ships I usually drill a hole in the underside near the base of the neck and glue in a piece of styrene tubing so I can insert a brass rod to hold it with while I spray it.
Post by mophius » Tue Feb 21, 2017 11:38 pm
I had it on an upturned aerosol lid so that it only touched in three places. Maybe I turned it over too quickly after a coating. I gave it two coats and I had a portable bar heater 18 inches away so that it dried quickly and was sure it was at least an hour before i turned it over.
The two marks on the rear I am sure are travel damage
