My first Arduino prototype!
Post by NCC1966 » Thu Jun 23, 2016 7:20 pm
Thanks to our mate Julien I got aware of a simple, smart and cheap thing called "Arduino" that now I can say is a MUST if you are thinking about to play with starships lighting!
After a few minutes browsing web I already was ordering one of those cards plus a few extra components (a breadboard and some wiring) that didn't cost me more than $10...
Today I picked it in my PO Box, ran for home, plugged it to my computer and in about 15 minutes (no kidding!) I had running what should be the first prototype of my 1/600 TOS Enterprise nacelles rotating effect!
My plan is to use 6 or 8 LEDs (depending on the diameter of the nacelle tip) mounted in a circular array.
:mrgreen:
My SECOND Arduino prototype!
Post by NCC1966 » Fri Jun 24, 2016 7:11 pm
Today I worked on a second prototype, this time trying to simulate navigation lights:
From the left to right:
1) Short pulse
2) Quick regular flash
3) Slow regular flash
4) Fading — very useful for deflectors, warp nacelles and charging photon torpedoes (no TOS)!
:mrgreen:
Of course the heart of this project is the program. All the parameters such as flash speed, duration of pulses, etc, can be easily adjusted by changing simple parameters and re-uploading the program to the card.
Re: My first Arduino prototype!
Post by Cubey Terra » Fri Jun 24, 2016 11:53 pm
Hey, maybe you can put an MP3 decoder module and amplifier on that and have your ship play Star Trek them music!
Post by NCC1966 » Sat Jun 25, 2016 12:06 am
Cubey Terra wrote:Hey, maybe you can put an MP3 decoder module and amplifier on that and have your ship play Star Trek them music!
This is a hell of a good idea! It would be nice if I could find a controllable module to play some effects too, such as phasers and photon torpedoes!
:mrgreen:
Post by MEATLOAFr » Sat Jun 25, 2016 3:09 pm
:mrgreen:
That would make it so cool I'd wet my pants in pleasure
Post by NCC1966 » Sun Jun 26, 2016 5:03 pm
Julien
Post by Julien » Thu Jun 30, 2016 4:05 pm
That's great ! It really took you no time at all to learn how to use that thing !
Post by MEATLOAFr » Fri Jul 01, 2016 12:09 am
NCC1966 wrote:Image
Post by NCC1966 » Fri Jul 01, 2016 3:12 pm
Julien wrote:That's great ! It really took you no time at all to learn how to use that thing !
Yah, Julien, it was surprisingly more cool and easier than I supposed!
I confess that when I opened up the package and looked at that small board I thought: "Yah, sure, another electronic funky stuff that I won't be able to put to work..."
I thought that it wouldn't even be recognized by USB (then you can see as I am incredulous these days). But then things started to happen one after other. When I ran the first "Hello world" small code that makes an onboard SMD LED flash I literally say a light by the end of the tunnel. From there it was just a few minutes until I hook a few LEDs in the breadboard and type in the code!
It never was so gratifying!
:mrgreen:
Post by NCC1966 » Fri Jul 01, 2016 3:16 pm
To whose has interest, here it goes the code to make the rotating brussards:
Sequential flash
Hook leds at the pins 6-9-10-11
each one in series with a 330R resistor
if you want more leds, just hook them
int tleds = 4; // the quantity of leds you are using
int pointer = 0;
int zz = 0;
int MyLed[] = {6,9,10,11}; // the output ports (pins) where your leds are hooked
// the setup routine runs once when you press reset:
void setup() {
// initialize ports
for (zz=0;zz<=tleds-1;zz++)
pinMode(MyLed[zz], OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
digitalWrite(MyLed[zz], LOW);
digitalWrite(MyLed[pointer], HIGH);
pointer++;
if (pointer > tleds-1)
pointer = 0;
// change the delay value in ms to adjust speed;
// the bigger the number the slower the speed
delay(120);
Return to “Lighting”
