Small windows - non FO options?
asmcelhinney
Post by asmcelhinney » Sun May 04, 2014 10:42 pm
Does anyone have any tips for filling little windows?
Specifically, I'm looking at my 1/2500 Enterprise E. The windows are long and irregular sizes. I don't think the simple drill and fill with fiber optic that looks so good on the smaller ships will work on this one.
So... has anyone tried using dental acrylic at this scale? I can't imagine it's as effective or easy to use on tiny windows.
What about Micro Krystal Klear, any experiences with that?
I've even heard (though not seen) that hot melt glue can be used for filling windows.
My fledgling YouTube channel:
indianatheshepherd
Re: Small windows - non FO options?
Post by indianatheshepherd » Mon May 05, 2014 12:40 am
For oblong windows I've used Micro Crystal Clear and Testor's Window Maker. They are both pretty much the same. Light does penetrate, but if the window is really narrow, it is only visible straight on, not at an angle because of the thickness of the plastic.
I haven't tried it yet, but it might help light up the windows if you ran fiber optics to the back of the window but used the Crystal Clear on the front... the fiber could possibly help illuminate the crystal clear so light is visible from wider angles.
Oh, and the more light you have inside, the better if you're only going to be using Crystal Clear... rather than individual LEDs, try using high density LED strip lighting.
Post by MEATLOAFr » Mon May 05, 2014 11:46 am
indianatheshepherd wrote:For oblong windows I've used Micro Crystal Clear and Testor's Window Maker. They are both pretty much the same. Light does penetrate, but if the window is really narrow, it is only visible straight on, not at an angle because of the thickness of the plastic.
What he said
asmcelhinney
Post by asmcelhinney » Mon May 05, 2014 12:22 pm
indianatheshepherd wrote: I haven't tried it yet, but it might help light up the windows if you ran fiber optics to the back of the window but used the Crystal Clear on the front... the fiber could possibly help illuminate the crystal clear so light is visible from wider angles.
That sounds like an interesting, if fiddly alternative. So I take it Micro Krystal Klear makes decent windows? I've only really heard of it being used as adhesive for clear plastic.
Post by Tesral » Mon May 05, 2014 4:33 pm
Have you considered melting the end of the fiber optic?
indianatheshepherd
Post by indianatheshepherd » Mon May 05, 2014 4:58 pm
asmcelhinney wrote:That sounds like an interesting, if fiddly alternative. So I take it Micro Krystal Klear makes decent windows? I've only really heard of it being used as adhesive for clear plastic.
Yes, it makes decent windows if the area being filled is small enough. Use a fine tip brush and apply to the inside of the hole. It's natural water tension will hold it in place. You can also apply scotch tape to the outside of the model and apply the Krystal Klear from the inside so when it drys it has a nice flat surface on the outside. I've seen people use this technique using clear epoxy as well, but for larger openings.
Keep in mind, both Krystal Kleer and the Testor's brand window maker may take awhile to dry because for windows they are being used as a filler... but when they do, they are in fact, clear.
Post by RogueWolf » Wed Dec 10, 2014 6:29 pm
A year ago or so my daughter had this silver gel pen. When the light caught the ink just right it almost looked like it was 'lighted' from behind. I tried it out on a model and it did look like the window was lit from behind. I'll see if I can find the pen or even go out and buy a new one and try this again and post pics of the results, it may be a workable option.
Post by Moongrim » Thu Dec 11, 2014 2:45 pm
RogueWolf wrote:A year ago or so my daughter had this silver gel pen. When the light caught the ink just right it almost looked like it was 'lighted' from behind. I tried it out on a model and it did look like the window was lit from behind. I'll see if I can find the pen or even go out and buy a new one and try this again and post pics of the results, it may be a workable option.
Be sure to Identify the make and model of that pen please.
Post by RogueWolf » Thu Dec 11, 2014 5:23 pm
I will if I can find it!
Post by RogueWolf » Sun Dec 14, 2014 1:26 am
OK, I couldn't find the original silver gel pen, I believe it dried up on me long ago. So I went to Wally World today and found these:
I looked for a smaller pen pack with just the silver and gold in them but couldn't find one. This set cost me $5.97 Cdn, I figure my friends to the south can get it for about $3 and change.
First the silver with no flash, I used an old 1/1400 Voyager;
And with Flash;
So the silver wasn't as good as I remembered with the flash on and off, but the light does catch it well and almost looks like there is internal lighting.
On to the Gold. Boy was I impressed!
Gold with flash on;
And with flash off;
I think that the gold might be worth your money if you want to have another option to window coloration. YMMV but I think I might give this a shot on some of my models.
Return to “Lighting”
