USS Antares - Remastered
Re: USS Antares - Remastered
Post by novahobbies » Fri Feb 22, 2019 12:49 am
Wow, looks great!
Post by trekriffic » Mon Feb 25, 2019 4:19 am
So I'm 99% done with the panel decaling and have painted the bussards, saucer domes, deflector, and running lights white. That makes a good base for the final colors later on. I also painted some of the accent colors with MM European Grey and Medium Grey or a mix of the two.
Once the paint has dried I'll coat with Future before applying the window, insignia and registration decals.
USS Antares - Aztec Done by trekriffic, on Flickr
Post by Tesral » Mon Feb 25, 2019 6:36 am
It is a interesting adaption of the design we first see in the animated series. I like where you are taking this.
Post by trekriffic » Fri Mar 01, 2019 2:12 am
So getting down to the detail painting all with a fine tipped brush. Painted the domes and bussards white previously as a basis for what is to come so now I've painted the upper crew module dome with a mix of three colors: Light Sea Gray, Flat White, and Flat Tan to make it sort of a muddy grey-ish light tan...
USS Antares - Paints+ by trekriffic, on Flickr
Upper dome brushed with mix of Light Sea Gray, Flat White, and Flat Tan.
Bussard domes painted Flat Yellow. After that dries I'll mix up some creamy orange to paint spokes:
USS Antares - Dome Details by trekriffic, on Flickr
So will paint the lower dome next and the next layer of the bussard domes. More Medium Grey accents have been added:
USS Antares - Still a WIP by trekriffic, on Flickr
I gave some of the paneling a light dry brush with Light Sea Gray. It turned out well; especially with the bands on the nacelles:
Bussards will eventually be a peachy orange cream with yellow between the spokes:
I made the lower hull "screen-like" panel Medium Grey to help balance out some of the Medium Grey accents up above. Plus it helps break up a lot of light grey:
I painted the back of the deflector dish light blue to mimic how it would appear reflecting the light blue "light" that comes from the light blue enamel painted "booster ring" behind it:
USS Antares - Dish back by trekriffic, on Flickr
More to come...
Post by trekriffic » Tue Mar 12, 2019 3:41 am
Finished all the detail painting.
I decided to go with the yellow-orange bussard domes like the Antares had in the remastered episode rather than try to do the spokes.
I also finished some odds and ends related to the aztec paneling.
Then I clipped the music wire to the desired length and glued the deflector dish in place.
I'll give her a flat coat before applying Tamiya pastel powders to give her a more metallic look.
Then another flat coat before coating with Future before applying the ship's windows, registry and insignia decals.
Then a gloss coat to seal the decals followed by another flat coat or two. Anything I want glossy (like windows, running and formation lights, and the bussards) I can then gloss up with a brush and some Future...
USS Antares - Final Paint by trekriffic, on Flickr
Post by TrekMD » Tue Mar 12, 2019 3:56 am
That looks awesome! Very well done!
Post by trekriffic » Mon Mar 25, 2019 10:27 pm
Got the decals done! I managed to mangle the ship's name and registry decal though so had to come up with a workaround using old leftover decals from my stash. Piecing together such small numbers and letters was intricate work using an exacto knife, tweezers and a magnifier but, all in all, it turned out very well. I am quite satisfied with the results...
It took three pieces from my leftover decal stash to replace the bow registry decal:
USS Antares Decals Done by trekriffic, on Flickr
Hmmmm... Not bad at all:
For the ship's name on the bow I repurposed the kit decal meant for the fantail:
To replace the kit decal, I sliced letters off the leftover decal sheet from the 1/1000 scale USS Phobos kit:
Altogether it took 5 pieces of decal material to make the ship's name on the stern:
I kept thinking that the large ovoid shaped panel on the forward face of the upper hull needed something and found this leftover 1/2500 Enterprise D decal from Absolute Models. The fan shaped section was the perfect size to fit:
Here it is freshly applied and brushed with MicroSOL decal setting solution:
Here are some teaser photos taken in my driveway in natural light:
I added red and green running lights to the top of the secondary hull on either side of the oval upper hull section. I figured the ship needed an extra set for when the bow crew module is detached and she's running in robotic mode:
I added some "purge vents" panels to the inside face of the nacelle struts:
I've sealed all decals with Future now and am going to spray her with Dullcote before applying some Tamiya pastel chalks to give her a more metallic look like in the remastered episode. Then she'll get a final flat coat before she's all done.
Then I'll take the "good" pics.
Post by TrekMD » Tue Mar 26, 2019 4:08 am
Wow, looks fantastic!
Richard Baker
Post by Richard Baker » Tue Mar 26, 2019 3:32 pm
I love the way this project turned out!
Post by novahobbies » Wed Mar 27, 2019 7:18 pm
WOW! Way to super-detail such a tiny model....good job!
