USS Antares - Remastered
Re: USS Antares - Remastered
Post by trekriffic » Thu Jan 10, 2019 11:41 pm
After letting the primer dry for a few days I brushed the underside with Model Master Flat Gull Grey using a mop brush:
USS Antares - Gull Grey Half Done by trekriffic, on Flickr
USS Antares - Gull Grey Brushed by trekriffic, on Flickr
I'll let the underside dry a day before I brush the top. The enamel went on fine over the primer this time. Once the top is done and dries a few days I'll seal with Future before adding some paneling in a slightly darker shade. Once the panels are all done I'll overspray with a thinned coat of Neutral grey lightened up a bit with white. When I'm done I want the paneling to barely show under the overall medium grey of the final hull coat.
Post by trekriffic » Sun Jan 13, 2019 11:21 pm
So did some work on the deflector dish. After combing thru my greeblie stashes I came up empty so resolved to make the dish from scratch using .040 syreene sheet and music wire...
The punch, the pinvise, and the router bit used to make the deflector dish shown. I also used a sanding stick:
USS Antares - Deflector Dish Tools by trekriffic, on Flickr
After hollowing out the lightly punched disc I punched it out from some .040 thick sheet using a punch tool and a hammer. Before that I drilled the center hole using a pinvise:
USS Antares - Concave Dish by trekriffic, on Flickr
After punching and hollowing out some .040 styreene using a round router bit in my handheld battery powered "dremel" tool I glued the blank to a short piece of music wire using Plastic Surgery CA glue:
USS Antares - Styrene Disc Glued by trekriffic, on Flickr
The backside was shaped with a diamond file and sanding stick to get the right curvature:
USS Antares - Deflector Dish Shaped by trekriffic, on Flickr
Deflector dish recess on lower hull. White will be over painted with transparent blue acrylic:
USS Antares - Deflector Dish Work by trekriffic, on Flickr
Need to lightly sand with 400 grit or lighter:
USS Antares - All Brushed Gull Grey by trekriffic, on Flickr
I've found some leftover decal material with panels from what I think was a 1/1000 scale Enterprise D kit so plenty of light grey panels to mix and match. They should work well over the flat gull grey hull. Of course being decals I'll need to gloss coat the hull first:
USS Antares - Gull Grey - Deflector Dish White Underpaint by trekriffic, on Flickr
ProfArturo
Post by ProfArturo » Mon Jan 14, 2019 12:03 am
Really enjoying these posts and the level of detail you put into them.
Gidiot
Post by Gidiot » Mon Jan 14, 2019 12:14 am
Gorgeous!
Post by Tesral » Mon Jan 14, 2019 4:02 am
I'm going to have to keep that home made dish in mind.
Post by trekriffic » Fri Feb 08, 2019 7:23 pm
Thought it was about time I added some new pics of my progress. I've probably spent a good 2-3 hours already cutting out bits of leftover aztec decals to add interesting detail to the hull.
Still need to do the top of the forward crew module, the upper and lower hull superstructures, the nacelles, and the sides so probably another few hour or so.
Once the decals are in place I apply MicroSet then let them dry for 15-20 minutes before brushing with Liquid Decal Film to seal them.
When I'm done aztecing I'll seal with a coat of future before adding the kit window, stripe and registry decals...
USS Antares - Aztecing by trekriffic, on Flickr
Post by Kremin » Sat Feb 09, 2019 2:02 am
Everytime I look at this ship with an eye to building one I get stuck on what size it's supposed to be. Any chance you can do a shot next to a Connie of the same scale
Post by trekriffic » Mon Feb 18, 2019 1:04 am
Sure thing. They ain't fancy seein' as I took'em in my dinin' room but here ya go!
USS Antares and Enterprise by trekriffic, on Flickr
Post by trekriffic » Mon Feb 18, 2019 1:06 am
USS Antares after some more aztec decaling this afternoon...
VImage
USS Antares by trekriffic, on Flickr
Post by trekriffic » Mon Feb 18, 2019 1:08 am
ImageUSS Antares by trekriffic, on Flickr
