USS Thomas, NCC-12863 - Indomitable-class, early 24th Century
Post by Griffworks » Thu Sep 13, 2018 2:46 am
About two months back, I started on the second Indomitable-class build. This one is Thomas, NCC-12863, named for Thomas Sasser. Custom decals just arrived today for this and for Sasser. The registry numbers are his birthday - December 8, 1963.
Nothing super special. The nacelles are meant to represent an experimental nacelle for this ship, which was commissioned in 2306. The nacelles are meant to be the grandpa of those seen on the Ambassador and Galaxy-classes of ships, which have similar wrap-around flux chillers.
The actual nacelles are the Talon-type nacelles from UGH! Models.
Gratuitous beauty shot!
This is my first time to successfully attach the ParaGrafix Modeling System PE for the planetary sensors. First time was about a year ago and I botched it pretty badly. I like it, thus far.
It's Tuesday and look what was installed in a timely fashion! Yes, she has photorp tubes.
No photon torpedoes, tho... Those'll be here next Tuesday, I heard.
Obligatory Album Link.
More later.
Re: USS Thomas, NCC-12863 - Indomitable-class, early 24th Century
Post by Griffworks » Thu Sep 13, 2018 2:47 am
Originally, I gave Thomas a slightly different looking impulse vent set. I didn't like the final result - it made me feel sorta queasy to my stomach - , so I changed it up. I gave her a single impulse vent, implying a single impulse engine instead of two like on the Enterprise, Miranda, and Excelsior designs. To my thinking, this shows further continuity going forward into the Lost Years Era for the Ambassador and Galaxy class ships which have a single main impulse drive.
From my greeblies supply, I pulled some WAVE Option System U-Vernier parts. These are designed originally for Gundam models, but work great for a variety of non-Gundam bits-n-bobs.
These are my greeblies! There are many like them, but these sets are mine!
Test fitting. I did some sanding to the top, specifically the corners in an attempt to get a better overall fit.
Sanding some Evergreen V-Groove to-fit inside the vernier.
And glued in place. I'll blend it all together a bit later.
More to come!
Post by kobayashimaru » Thu Sep 13, 2018 2:52 am
this has been a treat to watch form,
It's amazing how you're "greeble-izing" the 3D print
into an even more awesome ship.
I like that 'vectored' impulse vent grille you made, very neat!
Post by Griffworks » Thu Sep 13, 2018 4:45 am
Thank ya for the kind words! I appreciate it a great deal. I have a lot of fun doing any build, pretty much. Tho they can occasionally be trying at some point doing the build, they're totally worth it, IMNSHO! Well, unless you're dealing with a true dog of a kit.
I didn't like how the starboard photorp tube was angled, so removed it - and broke both the thin resin of the tube and the printed plastic of the housings outboard "wall". So, I replaced the photorp tube then found some Evergreen sheet stock roughly the same thickness as the surrounding shrowd area, very carefully cut the upper and lower "walls" to allow the addition of a new section, then glued it in place.
After one previous attempt, this is the final result. I think it looks pretty good. And, of course, please keep in mind that the camera shows detail that the human eye wouldn't normally catch unless you used a magnifying lense. That rough exterior doesn't really show up until you have the model like two inches from your Mk I Eyeball.
More to come.
Post by trekriffic » Thu Sep 13, 2018 4:54 pm
I like how this is turning out Jeff. Nice work and a fitting homage to Mister Sasser.
Post by Griffworks » Sun May 12, 2019 2:25 am
And decals from JBOT for this particular build, as well.
No new updates on the build.
Post by novahobbies » Mon May 13, 2019 12:51 pm
good lookin' decals! I like it! I need to get back to my Indomitable soon, just been having too much fun with the Klingons lately. :D Can't wait to see more pictures of yours!
Post by Tesral » Mon May 13, 2019 4:25 pm
"Fun with Klingons" bespeaks of bandages, and traction....
Post by Griffworks » Mon May 13, 2019 5:25 pm
And antibiotics....
srspicer
Post by srspicer » Sat May 18, 2019 5:21 pm
OMG Jeff, you deserve a medal for working with that material!!
