Polar Lights 1/1000 Oberth REVIEW - PART 2 - BUILDING!
Post by MEATLOAFr » Sat Sep 08, 2018 2:25 am
Got some building together of the Oberth kit… not much for details, but has some where they belong, but most detailing will be done by the decals - as this scale is accustomed to
Here’s a top shot with the “saucer” attached
Bottom of the upper hull
Some engraved rings on the underside of the “saucer” section
Maybe a little to wide for my taste, but we will see how they look when finished and they take some paint
Here’s the warp grills with the lower section of the nacelle
Lower hull pod
There is some nice details on the inside of the pylons
The warp nacelles
The nacelles are about 2 ½ inches long
One drawback of the Oberth kit that I have so far is there are some sink holes in both side of both nacelles where the peg hole is
So far this kit isn’t bad, flash isn’t bad as the Klingon kit. Details aren’t to bad, we will see how the decals trat up when it’s time for them
It will be a happy addition to the collection – as long as no one try’s to disable it with a torpedo
Will try to get paint on the kit this weekend, as long as weather here stays good
LINKS
AST 1/1000 Oberth & Klingon Bird of Prey REVIEW - PART 1 - Unboxing/First Impressions!
https://www.allscaletrek.com/viewtopic.php?f=7&t=5265
AST 1/1000 Klingon Bird of Prey REVIEW - PART 2 - BUILDING!
https://www.allscaletrek.com/viewtopic. ... 984#p68984
AST 1/1000 Oberth REVIEW - PART 2 - BUILDING!
https://www.allscaletrek.com/viewtopic. ... 983#p68983
Rio
Re: AST 1/1000 Oberth REVIEW - PART 2 - BUILDING!
Post by Rio » Sat Sep 15, 2018 4:36 pm
Thanks for the heads up and sharing!
The Oberth is one of my favorites designs ever from ST. I just wish it would be in a bigger scale, 1/350 would be perfect. But this is what we’ve got, and those of us lucky enough to get one from Ugh before they suddenly stopped production.
One peculiar aspect is the warp grill/nacelles; they are unique. Also the “mid deck” where everything attaches (sensor pod, suacer, engines) could be used as a base for modding, like the Jester. Also, the sensor pod is also a cool design unique to this ship.
Looking forward to procure this kit.
Happy Modeling!
Riö
Semper Sci Fi!
Post by MEATLOAFr » Tue Sep 18, 2018 2:58 am
Happy Modeling!
Riö
Semper Sci Fi!
maybe we will get a 1/350 if this kit does well enough, and I'll bet someone will have a Jester mod before to long
Post by MEATLOAFr » Tue Sep 18, 2018 2:59 am
Sorry for the lack of updates, annoying tropical depression kept it to wet to do any painting outside, and I have no place to do it indoors at this time.
I did manage to get the base coat and some detail painting done on the Oberth ship, I do need to go back and touch up the edges of some of the recesses.
Luckily this kit is easy to do, just 4 colors needed:
White for the main color
Aluminum for the sensor dome, bridge recess and the pod
Intermediate Blue for the recesses on the upper hull and the upper recces on the pylons
And Black (or in my case Gunmetal Grey) for the warp grills
I swear the paint just blead up and out of the recesses
Luckily the grills are a separation part and the separation line will be hidden
You can see here the horrible job I did on getting straight lines
One big gripe I have with the kit is that there is no paint guide on the instruction sheet – just color CG renderings on the box flaps, or is there a list of suggested colors anywhere – just has a “follow colors shown”
holt35
Re: Polar Lights 1/1000 Oberth REVIEW - PART 2 - BUILDING!
Post by holt35 » Wed Sep 19, 2018 11:25 pm
I'm enjoying the build Meatloafr! I started on mine today and was wondering if you had the same problem I did with the pylons tab holes being to small? I have to trim a good amount from the saucer holes before they would fit. Also I have to tell you my Bird of Prey didn't really have any flash on it at all so they must have fixed that issue.
Post by Tesral » Fri Sep 21, 2018 4:13 am
That is humidity for you.
Loving the build. You do good review.
Post by MEATLOAFr » Tue Sep 25, 2018 4:45 am
Quick update for those interested – sorry for falling behind, real life hasn’t been to kind the past few weeks
I started decaling the models today:
Upper Oberth Main Hull
Unfortunately most of the lower windows decals fell apart on me, and one of the half’s of the upper hull’s decals tore (which luckily I was able to salvage)
Upper Oberth Pod
Lower Pod
Decal set liberally applied
Sorry to say the decals seem to be up their old tricks:
The window decals just fell apparat on me – as you can see
Post by MEATLOAFr » Tue Sep 25, 2018 5:08 am
I haven't attached mine yet, I still need to do the lower half of the main hull's decals - I don't want to chance me breaking something when I test fit - the saucer holes were no problem for me
I am glad that the flash on the Klingon ship was just my bad luck
Post by Tesral » Tue Sep 25, 2018 7:42 pm
I'm starting to wonder if a shot of decal film over any R2 supplied decals should be SOP. A scan apparently must be.
Post by novahobbies » Wed Sep 26, 2018 3:27 pm
Agreed on both counts. Scan it to be safe. Shoot it w/ clear acrylic or Testors decal bonder just in case.
