Yay! And thanks! I like that I can actually serve as a positive example somewhere!
I appreciate the work you've put into yours, as well. You're going much more detailed than I, obviously, which makes me want to start mine over again. Sorta.
What is the diameter of the saucer of the sentinel class light cruiser and the length of the warp nacelles ? (Just to know if I can re-scale it for sacred scale, I like the shape , thanks )
At some point in the near-future, UGH! Models are going to release it in 1/2500, along with the Repulse - which I have the master parts for needing a quick one-over before sending out.
I’ll get you the stat’s on the saucer a bit later.
