Federation Class Starship- Long haul Project 08/27/2016
Re: Federation Class Starship- Long haul Project 08/27/2016
Post by Moongrim » Mon Nov 14, 2016 10:06 pm
It appears that Richard Baker is no longer on AST.
Post by Moongrim » Sat Nov 19, 2016 1:48 pm
They arrived.
I can now proceed.
Post by novahobbies » Mon Nov 21, 2016 11:59 pm
All right! How about some pictures of the parts? I'd love to see how they look!
Post by Tesral » Tue Nov 22, 2016 3:25 am
One banana, :dancingbanana: to keep you going,
Post by Moongrim » Tue Nov 22, 2016 2:18 pm
novahobbies wrote:All right! How about some pictures of the parts? I'd love to see how they look!
I can now proceed, after I get over this cold...
Post by Moongrim » Sat Nov 26, 2016 10:43 pm
The newly arrived secondary hull parts are in the back (of course) It comes in three segments.
The front and rear sections together make up a standard Enterprise Refit hull length.
I've got my sawn in half hull alongside it for comparison.
Now with the secondary insert- I have a secondary hull that will end up being a bit longer than I'd calculated. BUT this isn't canon- so what the hey? Also the insert doesn't expand/contract in circumference, so it essentially comes down to being an extender joining the front and back. Again, not quite Canon...
But, I'm not thinking I could do better. Beggers can't be choosers.
I'm also using a conversion kit for several parts, from Federation Models- It's the same one I used in my Ascension Class Dreadnought.
So at this point: It's trim the Balson Secondary Hull of it's sprue and then join the three sections together (hopefully correctly- as my brain isn't always firing on all four cylinders some of the time). I do believe that I will be reinforcing the strength of the hull with some metal rod inserts. That too will be a challenge in it's placement. As I will be using additional rods in the placement of both the center warp engine, and the support rod for the display base.
Sitting on the warp engines- is the preliminary pylon. I've carved it into an appropriate shape, and managed to find a good beveling tool- a standard kitchen knife sharpener. Luckily the wife hasn't discovered my secondary use of such or otherwise she'd have gotten a bit terse with me.
The secondary hull can be made with the shuttle bay doors open and it's interior does have the option of decoration of the interior. Unfortunately- mine instructions with the set- mention decals, but the decals didn't come with it.
Let the sprue carving begin!
Post by Moongrim » Sat Dec 10, 2016 4:26 pm
It's been slow going of late, so I've not had as much free time to get time for one of my favorite hobbies (after breathing). Work overtime is increasing - the company decided to let folk's go in preparation for the new Administration.
Here I've removed the sprue- and drilled holes in preparation for the joining of the hull pieces. I added the brass rods for extra stability in the long term. I used two part epoxy to solidify them into place in the center portion and eventually at their end points in each of the other hull pieces. And of course- CYA to join the hulls together.
Here is the joined product. It was a bit of a challenge insuring that the hull pieces were not only smooth/flat, but also lined up properly to match the hull lines. I must say Modular Models did a good job with making sure of such. But even the best- there are about two spots where I needed to make a groove or two to insure continuity between lines.
At this point I've marked out the center line to prep for the groove to emplace the neck and eventually the W.E.pylon. Judging the location, it appears that the best spot for the pylon will be just forward of the shuttle bay.
Post by Moongrim » Sun Dec 18, 2016 5:02 pm
It's rather hard to accomplish anything- when your house is either cut off from power, or you're having to work overtime because other places are cut off from power.
Post by Tesral » Sun Dec 18, 2016 6:06 pm
Give me power, power
Wonder working power.
Gidiot
Post by Gidiot » Wed Dec 21, 2016 11:33 am
Moongrim wrote:It's rather hard to accomplish anything- when your house is either cut off from power, or you're having to work overtime because other places are cut off from power.
But then, how else do you keep your reputation as a 'Miracle worker' ?
