Gizmotron Belknap Conversion
Lonewolf
Post by Lonewolf » Sat Oct 27, 2012 1:40 pm
This is an excellent conversion kit for the 1:1000 PL Enterprise, and I picked it up at WonderFest in 2006. The kit included an all-new secondary hull, navigational deflector, two warp nacelle pylons, and a full sheet of markings, including very subtle Aztec markings for the tops of the warp nacelles (faintly visible in the first two photos below). The navigational deflector is cast as a separate piece, and helps to bridge the gap between TOS and TMP by going with the more-modern TMP style.
This is another kit that I have to get around to doing an updated photo shoot for.
Shark
Re: Gizmotron Belknap Conversion
Post by Shark » Sat Oct 27, 2012 4:20 pm
Pretty cool looking ship, how was the fit between the saucer and the secondary hull? Like the name by the way ;)
Lonewolf
Post by Lonewolf » Mon Oct 29, 2012 12:52 am
There was no fit issue whatsoever. The only fit "problem" was on the port nacelle pylon, which wanted to cant outboard further than the starboard one did. A bit of careful sanding took care of that issue in short order. And I did have to widen the slot on the underside of the secondary hull to accept the flange on the bottom of the navigational deflector. The deflector is kinda "L" shaped, with the short arm of the "L" being the face of the deflector, and the long arm fitting into a corresponding slot on the underside of the hull.
Post by Griffworks » Sat Sep 22, 2018 4:45 am
Great work, Rich. I think she turned out looking nice and clean.
There's something about the design of this kit that sorta bugs me. Not sure what it is - and it has nothing to do with your build.
BTW, this is actually the Decatur concept/prototype design, not the "finished" version of the Belknap.
ProfArturo
Post by ProfArturo » Sat Sep 22, 2018 7:18 am
Definitely a nice build, but I reckon it's the pylons connecting too low on the hull which seems 'wrong'.
Post by Griffworks » Sun Sep 23, 2018 2:10 am
Well, yes and no. "Yes" the pylons are low on the secondary hull - but that's how they're designed. I think what's wrong is that they secondary hull is too round, compared to the original concept. As conceived, the secondary hull should be a bit "bulkier" in girth, as in the top of the three drawings below.
At least, I think that's what the issue is. I like the build as it's not at all a bad design. It's just not the way it should be for the concept, if only to my eyes.
I intend to eventually build the Decatur in her operational configuration by using the primary hull from a TOS kit, with some minor modifications. I'm not sure how to best modify the secondary hull, tho I'll pull out the poster and follow it.
It'll be both fun and challenging! :D
