Bragging Rights Contest 2015 - Eye of Error - Finished
The Eye of Error
Post by The Eye of Error » Fri Mar 20, 2015 4:13 am
With so many projects on my bench lately I ended up having a stockpile of bits left over. So I had an idea for a quick fun project that ended up becoming a wee bit more.
I’ve always wanted to make a wrecked starship model, with all the exposed decks and battle damage ever since I saw the battle of Wolf 359. I took what leftover bits I had and put together a refit Dreadnought Class with exposed decks made from various shapes of sheet styrene and brass etched mesh. I used some misc 40k Necron model parts to build up the exposed warp nacelle and deflector dish areas.
I put multiple flickering red and yellow LEDs to simulate fires. The effect is quite stunning.
Check out the video: https://youtu.be/Tdy7pKAq3ZU
Last edited by The Eye of Error on Sun Jun 21, 2015 3:03 am, edited 1 time in total.
The Eye of Error
Re: Bragging Rights Contest 2015 - Eye of Error's Entry
Post by The Eye of Error » Fri Mar 20, 2015 4:15 am
Oh Damn, I forgot we chose Auxiliary Ships..... Back to the drawing board.... :P
For real though, I got all the pars in for my USS Jenolan in 1K scale. I just need to start boring a ton of resin out so I can run wire and LEDs.
Post by el gato » Fri Mar 20, 2015 3:08 pm
The Eye of Error wrote:Check out the video: https://youtu.be/Tdy7pKAq3ZU
:o
The Eye of Error wrote:Oh Damn, I forgot we chose Auxiliary Ships..... Back to the drawing board.... :P
Heh, you beat me too it. I was going to say that while the light show is stunning and hypnotic, your entry is unauthorized :P
Seriously, beautiful work. I'm trying to steel myself to do a damaged starship. Can't seem to build up the guts
Post by RogueWolf » Sat Mar 21, 2015 12:17 pm
:drool:
OMFG! That is so cool! I'm so touched that you are building this awesome kit as a gift to me for my birthday.
The Eye of Error
Post by The Eye of Error » Mon Mar 30, 2015 1:42 am
Well guys now time for me to get down to business with my version of the Kobayashi Maru based on John Eaves sketches below.
I’m going with something closer to the first version using the Enterprise NX Refit as a base kit, mainly for the retro lower hull section. I began to glue and chop accordingly leaving the main pieces.
After the major chopping was done I began to plan out templates for the rear saucer pod which will be shuttle bays and the lower pontoon shaped cargo pods.
Now I need to begin chopping up some sheet styrene. I'll be using the method that I outlined in this tutorial a few years ago. http://eyeoferror.blogspot.com/2013/01/ ... icard.html
Also, I will be lighting this kit up naturally and creating custom aztec decals as well. :D
Post by Moongrim » Mon Mar 30, 2015 2:05 pm
8-)
Hmmmm
Post by RogueWolf » Thu Apr 30, 2015 1:23 pm
One month to deadline! Any Progress?
The Eye of Error
Post by The Eye of Error » Wed May 13, 2015 3:04 pm
Guys, don’t kill me, I’m switching directions once again! Recently when cleaning out my old hobby stuff I stumbled upon awesome 1996 Finescale Modeler article on building a Type 15 Shuttlepod. I just had to build it!
Specifically this shuttle with Geordie in it from The TNG episode "The Minds Eye"
I took the templates from the magazine and scaled them up and modified them for print.
I found a paper model online, but didn't like the overall proportions compared to the Finescale Modeler, but it did have pieces for an interior that I want to build.
From another article online I found great lcars for the control panels.
The original full-scale prop used car seats for the Shuttlepod. I was able to find 1/25 scale mini-van car seats on eBay that I will modify for the pod.
And the last thing I need is a 1/25 scale Geordie. Fortunately, the old Galoob TNG figures are in 1/25 scale. I have and old Geordie figure that I am reposing and detailing to give him a TNG uniform and a fruity cocktail in hand!
The Eye of Error
Post by The Eye of Error » Mon May 25, 2015 3:34 pm
Progress is rapid moving on the Shuttlepod project. Minor SNAFU; I started cutting the template up and realized the pod was too small for the Geordie figure. So I had to scale up to 1/20 scale instead of 1/25 scale.
The exteriors details are coming together.
The interior is almost done. just need a few cushioned wall panels on the doors. The roof will accommodate 2 small white LEDs. I was going to use either EL sheet or LED strips, but I’m trying to keep the power source to a 9v battery and keep it internal.
The seat is almost there. I chopped up and glued the 2 seats together to make 1 lager seat. I started sculpting the head cushion and seam filling. The base is made from bits I had laying around.
The main control console is almost done, need to trim flash and add extra details. I have 2 Lcards panels ready to go for it.
Post by el gato » Tue May 26, 2015 5:37 pm
Beautiful so far
Return to “2015 Group Build (Closed)”
