El Gato's entry: TOS Constellation Class - DONE!
Re: El Gato's entry: TOS Constellation Class
Post by MEATLOAFr » Sun Aug 07, 2016 1:55 am
Post by DefiantClient » Sun Aug 07, 2016 4:05 am
Looking good Gato 8-)
Post by el gato » Sun Aug 07, 2016 5:11 am
Thank you for the kind comments gents! Some new update pics. Although I'm not done, I included these so you can see some of the detail on the body a little better. Disclaimer: I used filler primer on this; that'll explain the "fleks" you'll see in these pics. This is because the acrylic material sands smooths on the top & bottom sides, but it's way too porous on the edges. You can see in some pics that my green filler material didn't do the job, so I'm going this route. It will mean a few primer-sand-repeat sessions:
A shot of the dual impulse engines, just because:
A beauty shot with the E:
handofmanos
Post by handofmanos » Sun Aug 07, 2016 8:02 am
This absolutely looks beautiful and detailed for such a small model. Looking forward to seeing more
Post by Moongrim » Sun Aug 07, 2016 12:58 pm
That juxtapose between the TOS Constellation and the Enterprise really brings out it's quality. And gives me a reappraisal of the original TNG episode showing of the Stargazer.
shiftdel
Post by shiftdel » Sun Aug 07, 2016 1:08 pm
Interesting to see it closer to the Connie, I never noticed how big the Constellation is until see your pic...
Post by el gato » Sun Aug 07, 2016 10:39 pm
shiftdel wrote:Interesting to see it closer to the Connie, I never noticed how big the Constellation is until see your pic...
In all honestly, the Constellation is longer, but I don't think it's necessarily bigger. Both are due to the length of the body and that there are four nacelles taking up a lot of space. But, the Constellation's saucer is only three decks taller and also lacks the Connie's engineering hull, so its volume is probably smaller. I put this build next to the 2500 Refit, and the Refit is as long as the Constellation.
shiftdel
Post by shiftdel » Tue Aug 09, 2016 12:29 pm
el gato wrote:In all honestly, the Constellation is longer, but I don't think it's necessarily bigger. Both are due to the length of the body and that there are four nacelles taking up a lot of space. But, the Constellation's saucer is only three decks taller and also lacks the Connie's engineering hull, so its volume is probably smaller. I put this build next to the 2500 Refit, and the Refit is as long as the Constellation.
After seeing your comment, I search for references and noticed that, actually, the Constellation is shorter or just a bit larger than the Constitution (refit). there are, of course, disagreement about the size of the Constellation.
Even considering a shorter size of 291 m for the Constellation, against 305 m for the Connie; it gave a volume of around 234 k cm3 for the Connie and 694 k cm3 for the Constellation. To get these values, I scaled the stl files of both ships on netfabb Studio to their equivalent in mm (1/1000 scale), and did the Standard Analysis to get the volume.
There may be differences regarding the accuracy of the models I used, but the general number should be closer...
Interesting...
Post by el gato » Tue Aug 09, 2016 6:53 pm
Huh, those interior volume calculations are interesting, shiftdel
Post by el gato » Sat Sep 03, 2016 5:24 pm
I've been meaning to post these for weeks. Base coat's on. Did most of the detail painting last week, hope to finish it today or tomorrow
