Kremin's smaller build Arminius Class PA ship (WITHDRAWN)
Re: Kremin's smaller build Arminius Class PA ship (prototype
Post by Kremin » Sun Apr 17, 2016 8:05 pm
well the first set was too small so I must have measured it wrong, not to worry I can still use them and I have cut new ones correct
Added the struts for the aft of the hull and to give strength to support the nacelles
and testing the top plate in place
the bottom plate is a slightly different shape as it is lower than the main hull so doesn't sit flush with it
Post by Drop_Bear » Thu Apr 21, 2016 12:53 pm
She's coming along nicely.
Post by Kremin » Sat May 28, 2016 4:40 pm
Got the phaser turrets this morning, just need to get a working arm to fit them
Julien
Re: Kremin's smaller build Arminius Class PA ship (prototype)
Post by Julien » Wed Jun 01, 2016 8:48 am
I like where this is going ! Amazing work !
Post by el gato » Wed Jun 01, 2016 11:28 pm
Julien wrote:I like where this is going ! Amazing work !
What he said. Looking forward to seeing more
Post by Kremin » Mon Jun 13, 2016 11:14 am
Had a bit of a set back with the build, somewhere I used the wrong paint on the bottom of the saucer and the whole thing turned into a crackle glaze look. So tried various methods of sanding, filling, stripping was on the verge of having to scrap it and as a last try I totally recoated the suface with a wood filler from a local DIY shop, It's not as smooth as I would like it but it'll have to do or I'll just take a hammer to it
Post by el gato » Mon Jun 13, 2016 7:41 pm
Wood filler? What did it do? Fill in the crackle? Did it adhere to the plastic OK?
Post by Kremin » Tue Jun 14, 2016 7:34 am
el gato wrote:Wood filler? What did it do? Fill in the crackle? Did it adhere to the plastic OK?
Yep seems to have adhered ok, in coming months I might try it on something bigger and see what it's like. Checking the tin it says it contains styrene and consistancy wise it's very similar to car body filler. I decided to try it after I had to use some on a door frame and was very suprised how smooth it sanded
this is the stuff and at £10 for over half a kilo reasonable price
Post by Kremin » Fri Aug 12, 2016 11:35 pm
Lighting test on bridge module sides need to be a bit more red but looks ok so far
Post by Kremin » Fri Aug 19, 2016 4:11 pm
Trying out Nacelle lights
Just going for a single red 10mm led for the bussard collectors
might leave them like this rather than putting the photo etch grill on
3 3mm LEDs drilled into part of the stand parts from the old refit kit
