Kremin's smaller build Arminius Class PA ship (WITHDRAWN)
Re: Kremin's smaller build Arminius Class PA ship (prototype
Post by Kremin » Fri Apr 08, 2016 8:04 pm
cut out the rough shape of the new B deck and glued some tabs on the underside to attach it
B deck attached trying out bridge in position
some filling to do aroung the edge
Post by Kremin » Fri Apr 08, 2016 8:07 pm
Just to show the difference the two hulls next to each other
Post by Kremin » Fri Apr 08, 2016 8:22 pm
by using hulls of different scales one of the problems is that the decks and window sizes are different
so using a method that an other model maker uses I cut an filed out a larger opening and used rectangular brass to get the shape right
Post by Kremin » Sun Apr 10, 2016 8:04 am
And the first set is in
Post by Cubey Terra » Sun Apr 10, 2016 9:48 pm
That's a cool idea for a build. I'm going to enjoy watching this one come together. :)
Post by Kremin » Mon Apr 11, 2016 2:54 am
Cubey Terra wrote:That's a cool idea for a build. I'm going to enjoy watching this one come together. :)
Thanks, It's probably going to end up taking more time and effort on this little build than I ever expected but I'm enjoying it and trying new things so what the hell
Post by Drop_Bear » Wed Apr 13, 2016 6:52 am
Oh, how I would love to play in 1:350... Interesting choice, using the Refit B/C deck. What scale is it? It looks like it came from a 1:537 Refit.
Post by Kremin » Wed Apr 13, 2016 5:49 pm
Drop_Bear wrote:Oh, how I would love to play in 1:350... Interesting choice, using the Refit B/C deck. What scale is it? It looks like it came from a 1:537 Refit.
It is indeed, good eye there. 1:350 is not such a scary place although there is nowhere near as much GK extras as 1:1000 or 1:537
Post by Kremin » Sat Apr 16, 2016 7:46 pm
More Plastic cutting
Hole on the Bow for the navigation deflector and mount
holes in the nacelles started to be drilled to allow a view of the glow of the warp coils, not sure now much will be seen through the photoetch but there will be some shape to it
also cut a section out the aft to extend the hull this meant I had to re-inforce the remaining parts with Plastruct
Post by Kremin » Sat Apr 16, 2016 7:57 pm
Computer time, spent a bit time setting up the designs to cut the addtional aft sections. This is just the top and sides
The sheet styreen thin enough to cut will need at least 2 layers for strength so most sections get cut twice
