half a saucer
From 2D to 3D. CGI to Old School sketches. Post all artwork here!
half a saucer
Post by Tesral » Thu Jun 23, 2016 8:03 am
I could use some help from the 3D gurus around here. I have the profile for half a saucer. I need a 3D mesh made of it I can print.
Anyone?
shiftdel
Re: half a saucer
Post by shiftdel » Thu Jun 23, 2016 10:01 am
Guess I can make it for you, is the profile a pic?
Re: half a saucer
Post by Tesral » Thu Jun 23, 2016 5:19 pm
shiftdel wrote:Guess I can make it for you, is the profile a pic?
Yes. It should be 57mm across when I print it. My knowledge of 3D programs is zip.
shiftdel
Re: half a saucer
Post by shiftdel » Fri Jun 24, 2016 1:50 am
Easy. Do you want the lateral of the saucer straight as the pic or slight inclined as the Connie one?
Re: half a saucer
Post by Tesral » Fri Jun 24, 2016 1:50 pm
shiftdel wrote:Easy. Do you want the lateral of the saucer straight as the pic or slight inclined as the Connie one?
Straight, two of these make one saucer. The plan is to make a half hull then amendment for the Various Ane ships of the first generation. Yes influenced by the Franz Joesph stuff. Resin casting is the eventual goal, but I need the half hull to get started.
A full saucer, with some amendments.
shiftdel
Re: half a saucer
Post by shiftdel » Sat Jun 25, 2016 9:46 am
OK< it is almost done. I will make 2 versions: 1 solid and another hollow, if you want to print it in better materials.
Re: half a saucer
Post by Tesral » Sun Jun 26, 2016 5:42 am
shiftdel wrote:OK< it is almost done. I will make 2 versions: 1 solid and another hollow, if you want to print it in better materials.
Cool. I'll see about getting it made at my maker space.
shiftdel
Re: half a saucer
Post by shiftdel » Sun Jun 26, 2016 11:02 pm
Here it is, just waiting your answer of my PM about the printing options to send you the files ;)
Tesral Saucer.jpg (10.77 KiB) Viewed 2845 times
Re: half a saucer
Post by Tesral » Tue Jun 28, 2016 3:15 pm
A thing of beauty.
Re: half a saucer
Post by Tesral » Sat Aug 06, 2016 2:41 am
Ordered from Shapeways. They have higher rez printers than 13 Detroit.
We shall soon see.
Return to “Trek Art”
