USS Sutherland refit WITHDRAWN
SingleMind
Re: USS Sutherland refit
Post by SingleMind » Fri Jun 06, 2014 4:21 pm
Here is my donor kit cut up arranged. Nothing is glued together just taped. the pencil lines are what I'm thinking of doing to the top. Kind of a Sovereign type wedge blending into the present impulse engines. Probably will look Titan-ish. Also going to add to the shuttlebay to make two doors that shoot out to either side of the pylon. I think i got this idea from your conversion thread el gato.
Post by el gato » Fri Jun 06, 2014 10:23 pm
You did a great job cutting out the saucer! :thumbsup: From my research, it doesn't look like the Nebula has those two phaser strips in the back of the saucer, but it doesn't mean you should get rid of them. After all, yours is a refit
SingleMind
Post by SingleMind » Sat Jun 07, 2014 12:41 am
It does seem silly to have them there. They have no line of fire. And thanks. I'm kinda cheating in that I am borrowing a friends unbuilt resin model and using it as a reference. His model has the phaser strips there now that I look at it.
Kratok
Post by Kratok » Thu Jun 12, 2014 1:31 am
Interesting concept.
I like the idea of incorporating the Sovereign wedge into the saucer as this is a refit.
Similar paint scheme?
Sovereign style lifeboats?
I look forward to seeing your progress on this.
SingleMind
Post by SingleMind » Tue Aug 19, 2014 4:25 pm
So i am not going to be getting this done for the contest. Real life has gotten in the way and work is going to get busy. ill be posting my progress in the 2500 scale once i get back to working on her. Looking forward to seeing all of your progress.
Xen
Re: USS Sutherland refit WITHDRAWN
Post by Xen » Tue Aug 19, 2014 11:09 pm
I will lock the contest thread and copy it over to the 1/2500 section, so you can continue your work when you have the time.
