Klingon Bird of Prey (final pics page 9)
Re: Klingon Bird-of-Prey
Post by Steam235 » Sat Aug 30, 2014 4:30 am
It is incredible. I'm still not quite sure how the wires reach into the wings but it is just FANTASTIC!
harristotle
Post by harristotle » Sun Aug 31, 2014 6:38 pm
You never cease to inspire me! Your work is amazing :D
"I'm your huckleberry"
Post by trekriffic » Tue Sep 02, 2014 7:51 pm
Steam235 wrote:It is incredible. I'm still not quite sure how the wires reach into the wings but it is just FANTASTIC!
Thanks Steamer! Here's a photo showing the wing wires encased in heatshrink tubing as they pass thru a brass tube into the fuselage on each side. The tubing prevents any abrasion of the wires:
Post by trekriffic » Tue Sep 02, 2014 8:06 pm
Weekend and holiday progress:
Here's the base. A size K plug is epoxied to the top of the tube which is made from Evergreen plastic tubing slid inside a brass tube. The base has a size M jack. I got the base at Michaels craft store and sprayed it with Tamiya Black lacquer over Krylon grey primer.. The tube is glued into the base using 5-Minute Epoxy followed by JB Weld:
The model on the base:
More work under the neck...
Triangular brackets for under the neck. Made from styrene strips grooved using a scribing tool. Sprayed with Tamiya silver:
Triangular brackets glued in place with Plastic Surgery glue then painted SAC Bomber Green:
The kit has molded stairstep panels that didn't really match the look of the rectangular framed louvered panels in the screencap so I made new panels using styrene sheet and some leftover strips of brass photo-etch. The panels were sprayed with Tamiya black and silver lacquer before being brushed with MM SAC Bomber Green enamel:
I filled the stairstep panels of the kit with AVES and after drying overnight filed and sanded them to provide a nice flat surface to which I glued the new panels using CA:
Engine light test. This image was taken before I add the "milk jug" plastic diffuser panels between the engine insert and the LEDs. The difference this makes is quite dramatic as you'll see in a forthcoming photo:
Anyway, that's it for today. Thanks for any comments!
Post by Steam235 » Wed Sep 03, 2014 2:19 am
:eek:WOW :eek:
harristotle
Post by harristotle » Wed Sep 03, 2014 11:51 pm
Where's the forthcoming photo!? lol looking great!
Post by Moongrim » Thu Sep 04, 2014 12:38 am
Mighty fine attention to detail. I bow down before the master...
Post by el gato » Thu Sep 04, 2014 11:17 pm
:-o :shock: :jawdrop:
Bravo! Dare I say your build is "trekriffic"?
Post by trekriffic » Sun Sep 07, 2014 5:16 am
Thanks guys!
Here's the diffusion material cut from a Cafe Steamer meal bowl:
After trimming to fit the panels were brushed with Tamiya transparent red acrylic:
Some of the armor paneling detail around the mouth of the photorp emitter seemed a little soft to me so I cut new panels from styrene sheet to glue over the top of the kit panels using "Plastic Surgery" glue. First I had to scrape away the layers of paint to get down to the kit plastic. The glue dries in about 5 seconds so you have to be quick to get the panels aligned properly before the glue dries:
The new armor plating done:
Shifting gears...
The photorp tube was glued into position under the neck:
The cloaking generator ring was weathered and test fit. May be a little too weathered:
I mix my paints on aluminum foil for the various accent colors:
Looking at photos of the studio model revealed some details missing from the stern walls in front of the warp/impulse engines. Styrene strips were cut and glued to the sides:
A rectangular panel of grooved styrene sheet was trimmed to fit over the putty filled gap at the top edge of the warp engine insert. This matches the studio model:
The first round of weathering was completed by giving the model a brushing with thinned black enamel with a little neutral grey mixed in. I used tired mineral spirits from my brush cleaning jar. Fresh thinner woudl be too strong and destroy the underlying paint layers:
Some rust panels and accents were added:
The new diffusion panels give the engines a more even glow:
After a few days I'll go in with a rust wash in selected areas. Then she dries for a few more days, gets a shot of Dullcote to seal, then I start in with some pastels and ink pens.
I gotta say guys weathering the KBOP is a blast. It would be easy to get carried away; contrary to what one might think, if you try hard enough, it is posssible to overweather this ship.
Post by RogueWolf » Mon Sep 08, 2014 12:36 pm
I can't beleive how much work you have put into this build! I can't wait till Christmas Morning to open this up from under the tree. Realy, you shouldn't have! All this fuss for little 'ole me. Now, what should I get you?
I know!
SOCKS!!!
