USS SULACO
Gidiot
USS SULACO
Post by Gidiot » Thu Jul 27, 2017 7:28 am
Building up (with a buddy doing the "Heavy lifting"...) a 1/350 Refit, but you know me, gotta break (or bend) the rules a bit. why not cross the steams? Hence the USS Ripley ( baker class) and here now is the USS SULACO... here's the first bit... (disclaimer... I don't know why some images are rotated.... oh well...)
Planetary Sensor dome Light Test:
lighting set up (speaker will be in the saucer as well)
Engineering hull pieces...
Gluing the saucer together
So using the iridescent paints for the Aztecing on the belly section
Expanded out
sides, and outer nacelle struts
Inner Nacelle struts
Coloring in the Vents
more of the same (and more of the Aztecing
Above
above
Deflector housing
Close up... (maybe too close I see the little flaws....)
so, we added the Blue/Green underneath the Strongback and there's a cool effect under the decal....
random b/c deck image... ?
neck section
more Bridge? well it's here and we'll update that later....
ah... here we go... decals are starting to be applied
Early Shuttle Bay look.... Soon to have "Bug Stompers" logo and Dropships!
lighting test (pre-painting)
Gidiot
Re: USS SULACO
Post by Gidiot » Thu Jul 27, 2017 6:42 pm
small update,
here is the deflector with 90% of the work done, it will be the last piece added as that's where we're accessing the wiring...
and here is the secondary hull all light up... you may notice the Colonial USMC symbol has replaced the traditional delta of the movie-on up era...
and finally the Bug Stomper decal... little darker than I was hoping for, but still has the right Idea... it's also slightly oversized for what would have been "perfect" but as I've run out of decal paper for a little while it's what I get!
Re: USS SULACO
Post by MEATLOAFr » Thu Jul 27, 2017 11:32 pm
I LIKE
Re: USS SULACO
Post by Griffworks » Fri Jul 28, 2017 1:10 am
Heck yeah!
Gidiot
Re: USS SULACO
Post by Gidiot » Tue Aug 01, 2017 11:02 pm
some bridge work and getting ready for the Aztecing of the saucer!
Screen Shot 2017-08-01 at 3.55.54 PM.png (208.06 KiB) Viewed 1737 times
Hossfly72
Re: USS SULACO
Post by Hossfly72 » Wed Aug 02, 2017 12:25 am
This is phenomenal!
Gidiot
Re: USS SULACO
Post by Gidiot » Wed Aug 02, 2017 1:56 pm
and here is the (almost) finished upper saucer, primary and tertiary color patterns done.
will be working on the bottom 1/2 later, then the outer ring and edge of the saucer.... then decals, connecting the saucer to the secondary hull.... then on to the engines!
Gidiot
Re: USS SULACO
Post by Gidiot » Thu Aug 03, 2017 6:52 pm
so here's the finished "coloring" for the top including the escape hatches and are those cargo doors aft of the B/C deck? Maybe for working on larger segments of the impulse deck equipment?
so adding the Hatches:
Final look:
Self Lit Saucer and how it looks:
now to work on the bottom!
patrickivan
Re: USS SULACO
Post by patrickivan » Fri Aug 11, 2017 12:47 am
That is some nice painting there.
"I drink to make people interesting"
George Nathan
Gidiot
Re: USS SULACO
Post by Gidiot » Sat Aug 12, 2017 3:50 am
Lower Area right above the planetary sensors....:
