Orion Wanderer
Re: Orion Wanderer
Post by Kremin » Sat Jun 24, 2017 10:55 am
Thanks to JBot I have decals for her and other projects
Re: Orion Wanderer
Post by Kremin » Sat Jun 24, 2017 3:25 pm
New Topside paint scheme, decals, grime and weapons pods
Gidiot
Re: Orion Wanderer
Post by Gidiot » Sat Jun 24, 2017 5:38 pm
oh, my little projects are way above my current level....I have 3 in mind.... all in 1/1000 (at least for now)
The three I have in mind are a Northampton Class With Excelsior type upgrades. I think I would use a 1/1400 saucer and engines (I want it to be much smaller than a 1/1000 Excelsior class- just have familial similarities)...
I've also considered a "refit" style but with a much lower profile:
Then there's the Thufir class, I'm still deciding if I should do it as drawn here or close the catamaran hull, move the warp engines to the "wings" and make it more like a pre-cursor to the Saber Class... I can add an image - once I've created it ;)
and another one of my favorites, the Remora Class upgrade, CrazyEddies does a 1/1400, where if I could get them to either enlarge the bridge module or leave it off all together, it is the PERFECT scale for a 1/1000 scaled Remora refit... (I think it should as an Escort be more defiant size than just smaller than the ⅔'s as listed in the FASA manual...) I've also borrowed the "Shoulder" pieces from the Northampton refit to give a better place to add the Nacelle attachments...
I will be trying out how to do it on a 1/1000 excelsior saucer (it got somewhat damaged when the paint didn't work right so I won't feel too bad about completely destroying it now).... but as this really will be my first attempt at any true kit bashing besides just making Part A go to area B... well we'll see. And as I'll already be shelling out as much $ as Paul01 Can handle with his upcoming releases I can't really bug him to scratch build them for me!
Re: Orion Wanderer
Post by Kremin » Sat Jun 24, 2017 6:19 pm
No reason they cant be done the Remora will probably be the easiest to do the Northampton may need some structural support for the nacelles
I have used several mixes of scale to represent smaller classes of ship
My Remora had a 1:537 hull with a modified bridge and B/C deck in 1:350
My incomplete baker class uses 2 1:537 hulls to give the right thickness but 1:350 (Shortened) Nacelles
and my PA ship used a 1:500 jj prise primary hull
Gidiot
Re: Orion Wanderer
Post by Gidiot » Sun Jun 25, 2017 5:31 am
Here's the other ship with using the Thufir as the starting point.... not sure what to call it, but it's probably a frigate of some sort...
Not 100% on the Side view... it needs less secondary hull I think... but I'm tired and can't fidget anymore tonight... ;)
Gidiot
Re: Orion Wanderer
Post by Gidiot » Sun Jun 25, 2017 5:42 am
Kremin wrote: My incomplete baker class uses 2 1:537 hulls to give the right thickness but 1:350 (Shortened) Nacelles
I remember this one! here's the Almost completed version (but in 1/1000, not 1/350) I can't wait to see your once it's done too!
Primary Hull
Engineering Hull
Belly of the Beast
Next to the Reliant for Scale
Re: Orion Wanderer
Post by Kremin » Thu Jul 13, 2017 10:23 am
Updated most of the pictures to a new hosting service just hope nothing else goes wrong
there will be some gaps but they are not a top priority at the moment
Re: Orion Wanderer
Post by Griffworks » Fri Jul 28, 2017 1:14 am
Been enjoying the build pics. Great work! I found an Orion Wanderer on Shapeways and requested it be enlarged to 1k scale because of your build. Thank you for the inspiration!
Now I just gotta buy the thing....
