Tail section where engineering lives
the largest piece of the nose section
the rough casting for the bridge after much cleaning sanding and shaping of the super structure this ended up fitting better backwards
the Nose was attached to the lower bulkhead
some Plastruct was used as spacer between the top and bottom of the nose section then filler to close it up and shape the curve then a metal beam melted through both sides of the engineering section to mount the nacelles on
a resin cast from a cooking spoon was trimmed to give the curve for the forward structure and sheet styreen cut slightly wider than the flat shape was curved over to form the rear superstructure
then I melted mount holes in the nacelles and put them on to see how they look
Imgur test
