Photo etch parts
Photo etch parts
Post by MEATLOAFr » Thu Dec 19, 2013 2:48 am
I have a question about some photo-etched parts.
To anneal them, can I use a candle flame or does it have to be a butane torch?
I just don't want to go out and by one to find out it was overkill.
Also any tips/tricks to getting them to adhere to polystyrene and resin?
I'm doing the DLM phaser strips & other photo-etched accessories to a 1/1400 galaxy
Re: Photo etch parts
Post by Tesral » Thu Dec 19, 2013 6:14 am
The latter answer is CA. The thin stuff. The former I don't know.
Post by Moongrim » Thu Dec 19, 2013 4:03 pm
From what I remember from the annealing I did with copper pipes back in tech school- is that you want the flame that will be annealing, hot enough to burn blue.
I'm afraid that a blue colored candle won't do.
However, if you do have spare/leftover/sprue etch kit parts, you could try such on a test piece of styrene.
Post by MEATLOAFr » Fri Dec 20, 2013 2:49 am
well thanks, I'll cut a piece from the side and see what happens with the annealing and adhesion
Post by MEATLOAFr » Sat Jan 18, 2014 9:54 pm
Have a small butane torch comming that I bought off evilBay, hopefully it will work
then I will pick up some CA and test out on some scraps
Have a AGT Galaxy to build and have to modify some extra Photo-etch to the extra phaser strips on the Starcrafts add-on
I do wish the parts were in clear though, and the middle pylon was hollow, would make what I want to do to it so much easier
Post by Moongrim » Sun Jan 19, 2014 1:18 am
But if it was easier....it'd be....well....I guess....my train of thought got derailed... :imsorry:
Greyryder
Post by Greyryder » Sun Jan 19, 2014 1:21 am
Moongrim wrote:But if it was easier....it'd be....well....I guess....my train of thought got derailed... :imsorry:
Probably shouldn't have used Penn Central. :P
jjsmn
Post by jjsmn » Sun Feb 28, 2016 1:24 am
With regard to annealing in brass, when I was heavily into wooden ship modeling, the recommendation was always to quench the brass in water when red hot to anneal. That's the way I did it, and the brass did turn out soft. This is totally different than what is done with steels and other hard metals. I think it may have to do with brass being copper based.
I am not sure what the current brass annealing wisdom is?? :shock: Looking at the internet, I get the feeling that it may not hurt to quench, but am not sure whether it is necessary to quench.
Any thoughts???
Not trying to hijack thread! :mrgreen:
JJS
Post by Kremin » Mon Feb 29, 2016 10:46 am
Post by MEATLOAFr » Tue Mar 01, 2016 3:19 am
whoa, forgot about this - and here I was actually looking at the parts yesterday and daydreaming about working on it today
Return to “Customizing”
