Finishing a 3D printed model?
Re: Finishing a 3D printed model?
Post by Tesral » Wed Jan 08, 2014 5:25 am
Moongrim wrote:I As to drilling (if you need to), you're gonna end up with a WSF covered drill bit that takes forever to clean off.
s l o w d o w n.
When drilling any kind of plastic I crank the drill speed tn the lowest setting and gradually increase until I get effective drilling without melting.
zookman
Post by zookman » Wed Jan 08, 2014 11:51 am
i very rarely use a power drill in my builds ive got a small set of bits i can use by hand tho they do come with a small battery powered drill and it dont turn very fast itself even with fresh batteries . tho im also limited to only 6-7 different sizes for now
Post by el gato » Wed Jan 08, 2014 4:01 pm
s l o w d o w n.
Same here. I prefer my power drill over my dremel for that reason. With the trigger I feel I have more control over the speed. I have yet to melt a model
Post by Moongrim » Wed Jan 08, 2014 4:07 pm
Well you need to be able to penetrate said model in order to make any headway. That WSF plastic is tough, but it's also prone to melting (which is why they use it).
Regular sanding becomes a exercise in futility.
Slowdown? No sweat. I can sit and drill all day doing that.
Xen
Post by Xen » Wed Jan 08, 2014 5:39 pm
I wonder if folks would be more willing to pay for the higher priced materials, if they knew what it took to make WSF look good. We could do with a review of a few ships in different materials. Personally, I'd only go for FUD. It's a fitting acronym, considering that's the sound your shocked, unconscious self makes, when you've collapsed after seeing the price. :innocent:
Post by el gato » Wed Jan 08, 2014 8:18 pm
I'm not questioning anybody else's mad modeling skills. But it is important to stress that WSF, or any other plastic Shapeways uses, is a different beast than the stuff we're normally used to (remember Q's admonishment to Picard about how the Federation measures itself against "pathetic" adversaries like the Klingons and Romulans? Substitute resin and styrene for the last two). So if you haven't tried working with it, feel free to contact us that have. I know that Moongrim, Tesral and I have had stuff printed and had to work with it, as opposed to others who have stuff printed for the purpose of using them as masters.
Post by Tesral » Thu Jan 09, 2014 3:34 pm
Various types of ABS. Tough stuff indeed. Lego is made from ABS.
Greyryder
Post by Greyryder » Fri Jan 10, 2014 12:04 am
Having customized GI Joe and Transformers toys, ABS doesn't bother me. Nylon, on the other hand, I hate that stuff.
dJiPi
Post by dJiPi » Mon Nov 07, 2016 4:40 pm
Hi folks, hi E.G.,
Some of you are referring to Bondo, what's that, have any picture so I can ask my local retailer to try to get some ?
Thanks.
dJiPi the froggy
Post by Moongrim » Mon Nov 07, 2016 5:00 pm
dJiPi wrote:Hi folks, hi E.G.,
Thanks.
This stuff:
http://bondo.com/bondo-all-purpose-putt ... Bu3STjC.97
You'll want to use it in a WELL Ventilated area- as it reeks.
Automobile putty.
