I thought I might do a few making of posts of the masters for the old resin kits I produced way-back-when in case some of the techniques are of use to any of you. Most of what I did was always meant for molding, so they didn't need to be permanent, but some of the tricks would still work for final detailing.
I don't have tons of pictures because I hate stopping the momentum to take photos (or to, you know, EAT) I apologize for the poor resolution but these were state-of-the-art 25 years ago
First up is the Olympic:
The primary hull was made from a plastic fishing bobber:
The grid lines and windows were cut and laid out with 1/64" wide graphic tape. Life pods and other raised details were cut from sheet vinyl and laid out to be left in-place for molding.
The secondary hull structure was made from sheet styrene. The tape-and-primer method was used again for the grid lines and windows, and vinyl for the life pods.
After all details were laid out, several thin coats of sand-able primer were sprayed on with a light sanding between coats. When the primer was flush with the graphic tape, I'd trace the tape with a sharp Exacto and peel it off. This gave me the results of recessed windows and "scribed" panel lines.
The tape-and-primer method was the go-to technique for ILM on studio models and works very well.
The pylon section was sculpted from styrene and a material known as Sintra. It is an expanded PVC board and was a fantastic material to work with. The little light at the rear was made from a plastic rivet head from a model railroad set. Details were added with strip styrene and T&P.
I didn't want to sculpt two engines so I made one using a square, plastic tube as the base and inserted a square rod with the bussard collector on it. After it was molded the bussard was slid out and flipped and the "second" engine was molded. The recessed area was, of course, done with T&P. I know, what a lazy bastard
Finished casting:
Can also be viewed here: https://tmlindsey.com/tmlproject-Olympi ... uction.htm
Blast from the past: Sculpting my 1:2500 Olympic
- tmlindsey
- Charismatic Commander
Tim L.
https://www.tmlindsey.com
- RogueWolf
- Velutinous Vice Admiral
Re: Blast from the past: Sculpting my 1/2500 Olympic
Awesome blast from the past, thanks for sharing this with us!
- Kratok
- Perhaps today IS a good day to model
Seconded!
I was lucky enough to acquire copies of several of your releases in a trade with a friend some time ago. He had stopped building 1:2500 scale, and was kind enough to offer them to me.
They are still exceptional kits, all these years later. I am really looking forward to seeing how the original masters came together.
- Tesral
- Administrator
I have a number of Tim's kits and love them. Easy to put together? Nooo. Worth it? Hell yes.
- Ryan
- Lighting Fast Lieutenant JG
Thanks for posting the method for producing these.
Any other tips are welcome!
Ryan
Ryan
- tmlindsey
Frustratingly, there might not be much more since the majority of the pictures are apparently lost
Tim L.
