DECAL REMOVAL QUESTION
patrickivan
Post by patrickivan » Wed Mar 13, 2019 3:51 pm
Hi
I applied some aftermarket decals sheets to the neck and nacelle struts to my 1:350 TMP E, and the colours on the decals are almost invisible in any lighting.
What are your thoughts to removing them?
They were applied with decal set, but not clear coated yet.
Re: DECAL REMOVAL QUESTION
Post by mophius » Wed Mar 13, 2019 5:14 pm
Microset should be able to get them off. If you don't have any then some watered white vinegar should be almost the same.
patrickivan
Post by patrickivan » Thu Mar 14, 2019 12:32 pm
I'll probably try the less expensive option you suggest. I have plenty of vinegar. Thanks.
Mark2000
Post by Mark2000 » Tue May 07, 2019 12:52 am
Use some masking tape to pull them off. Just press it on firmly and rip it off fast like a Brazilian wax job.
