Fixing mis-drilled holes
Harrypotter
Post by Harrypotter » Wed Oct 21, 2015 9:33 am
Guys,
Essentially I started to drill the windows out for my 1/1000 D7 last night and had a bit of a nightmare.
2 of the holes are maybe 0.25mm out of position, which doesn't sound much until you consider the holes are 0.5mm in diameter, in which case it's a country mile.
Also I was having trouble drilling the double holes to make the slotted windows.
This is a test piece to learn how to get it right before I move onto other things (1/1000 TOS Enterprise), so before I start trying to fix it I thought I'd ask for your collective wisdom.
So please, how do I:
i) Fill in and re-drill the holes (techniques materials, tips & tricks etc.)
ii) Drill the remaining holes more accurately (I stopped once it started going arwy) - currently I was using a pin to 'centre punch' the plastic.
iii) Any other useful tips - I've tried googling it but you get lots of different answers and very little that translates to holes this small.
TIA
zookman
Re: Fixing mis-drilled holes
Post by zookman » Thu Oct 22, 2015 1:57 am
if ya have any plastic rod the same dia as holes .. just glue a small piece in let dry and trim and sand flush .. its plastic so is same strength as rest of kit .. if no rod then use the kit sprues and heat it and stretch it till it will fit in hole fairly tight so no gaps .. after trimming and sanding it should blend in nice lol .. might have to practice getting the stretched sprue the right size .. but it will taper ead the ends ya holding on so should get a couple pieces to fit lol
Post by Moongrim » Thu Oct 22, 2015 1:27 pm
Two part epoxy is 'good' for filling in the holes. JB Weld is my personal favorite.
Apply, dry, then take a hand drill bit set Image
Restart with the smallest bit for placement, use the larger bits for the window size you desire.
For making slits- make a starter hole for each end of the slit. And a number of additional holes along the line of the slit.
Start with one end hole, with the drill bit in it, and sort of 'shave' it towards the next hole along the line. But be warned- drill bits are not designed to withstand such use. They WILL break. So get yourself plenty of them from a cheap knock off hardware store along the lines of Harbor Freight.
Post by el gato » Sat Mar 12, 2016 3:50 am
How about just using putty to fill the holes? Tape one side of the plastic, apply the putty though the other side and sand flush if necessary
Post by Tesral » Sat Mar 12, 2016 5:54 am
el gato wrote:How about just using putty to fill the holes? Tape one side of the plastic, apply the putty though the other side and sand flush if necessary
Putty lacks any substance. The drill will slip right back into the old hole.
Post by DefiantClient » Sat Mar 12, 2016 4:46 pm
I've used this clay called Green Stuff which usually plays nice when you need to drill holes. I've seen it also called Brown Stuff and Grey Stuff as well, which I believe are no difference. It can be used for filling but sculpting is where it shines, which is why I think it holds up a little stronger when it dries.
Post by el gato » Mon Mar 14, 2016 5:02 pm
Good point. My shorthand failed me, because I call Aves "putty," even though they're different.
The other thing he can try, even thought it's tricky and if you let it dry too long you'll destroy your sandpaper files, is CA (crazy glue)
