Back in 2007 I had started a phaser I based largely on the Franz Joseph design, but had stopped because I really wanted something closer to the actual TOS prop. That earlier phaser had been made from paper, foam core board and Elmer's glue... all things I still have, so that seemed like a good place to start.
Wanting something closer to the actual TOS prop, I started looking at reference images to get a feel for what I'd be sculpting. In addition to plans, measurements and photos of surviving props, I collected together a bunch of screen caps of the props while in use.
With the info at hand I cut out foam core sections and started filling/shaping, until I started to get what I wanted. I then started working on creating a surface that match the finish I was going for. Once I was pretty happy I masked off some of the key features and hit it with a couple coats of primer to see how it looked. I spotted some defects, touched them up with glazing putty, and had another round of priming.
At the same time I put together some of the detail pieces, and when everything looked good, I made molds of them.
Just in case, I cast enough parts to make two phasers. I cut the needed openings and added the needed additional details. I also started in on the parts that would be directly made for each phaser (rather than cast).
Everything worked out pretty good. I was forced to use the remainder of some clear resin I had which had yellowed, but like I stated earlier, I had to use what I had on hand.
I still have the phaser start from 2007 (and it is still unfinished), I have since brought it back towards the Franz Joseph design's details (originally I had pushed it towards the prop's details). Here is a comparison of it with one of the new phasers (and some of the progress shots from back in 2007 when I first made it).
So there you have it, my simple, quick-n-dirty phaser I project.
