STAR TREK Size Chart
shiftdel
Re: STAR TREK Size Chart
Post by shiftdel » Mon Jul 16, 2018 12:26 pm
TrekMD wrote:...I think this impression from TNG "The Neutral Zone" is the only screencap in which you can realize the size
Sorry for resurrect this old post, but I found it just now, and actually there is another episode which allows for a better size estimation, it is season 3 episode 20 "Tin Man", where a Romulan Warbird pass exactly over the Enterprise, shotting at it on the process, and disabling it. The scene is fast, but as it pass over the enterprise, there are less perspective distortion.
I will try to get a better shot, as if I am not wrong, on the sequence of this scene, there is a side view which shows the Warbird passing over the Enterprise.
Post by TrekMD » Tue Jul 17, 2018 1:27 am
Yes, that's one of the instances where you can see the scale is off. The Warbird doesn't look quite as large as it is supposed to be, if I remember correctly.
FLEETYARD
Post by FLEETYARD » Wed Jul 25, 2018 6:51 am
kobayashimaru wrote:
Mon Jul 16, 2018 12:20 am
@fleetyard
does that revise the Oberth's overall length and beam as an increase or decrease to the overall dimensions? ...
Between each deck of Starfleet ships are Jeffries tubes. If the Oberth class were only 120,4m long, then it would have a deck height of 2,9m (-1m Jeffries tube = 1,9m for a room). That's just too small to be credible. That's why the Oberth class is bigger than on the ILM Size Chart.
FLEETYARD
Post by FLEETYARD » Fri Aug 03, 2018 8:06 am
FLEETYARD
Post by FLEETYARD » Fri Aug 03, 2018 8:08 am
FLEETYARD
Post by FLEETYARD » Thu Sep 20, 2018 7:22 am
The new "old" TOS Enterprise seen in Discovery:
https://fleetyard.blogspot.com/2018/09/ ... -from.html
nova1972x
Post by nova1972x » Thu Oct 04, 2018 8:52 pm
I do NOT like or watch STD, but I really like the STD Enterprise. It is what the JJprise should have been!
Post by Tesral » Fri Oct 05, 2018 3:18 pm
I'm going to grump about the unnecessary changes, but yes. The JJprise is horrible. Even if you know nothing about Star Trek it is an unaesthetic beast, Based on the Golden Mean alone it sucks. (The Jefferies Enterprise is in accord with the golden mean in case you wondered.) The STD Enterprise is closer to the original proportions.
nova1972x
Post by nova1972x » Thu Oct 11, 2018 7:22 pm
I watched a youtube video (not sure which one to be honest...probably trekyards) where it was explained that CBS had some weird legal reason they had to change the Enterprise by something like 25% from TOS. From a canon perspective, it makes no sense to have the Enterprise appear as it does in Discovery, but that does explain the real world reason.
In my own head canon, that design would work for a Phase II era Enterprise, though. It does look like a cross between the TMP refit and TOS Jefferies version.
ProfArturo
Post by ProfArturo » Fri Oct 12, 2018 6:49 am
I'm not buying it, surely one either has the rights to use something or they do not, rather than an arbitrary percentage of it.
