Clear resin casting recommendation
Scratchbuilding, kitbashing, reposing and other modifications.
MadManMUC
Postby MadManMUC » Sun Dec 31, 2017 11:50 am
So, I'm thinking of ordering an Oomoo 30 kit because there are some clear parts I'd like to cast myself.
Having never done this before, I'm not at all sure which clear resin I should use with the silicone rubber moulds.
The Smooth-On Smooth Cast 61D is listed as being 'transluscent white', but I really don't know how transluscent they mean, in terms of allowing light through.
On the other hand, their Crystal Clear series is listed as being for industrial applications only, and I really don't know if I could use it with the Oomoo mould.
Any recos for something caveman-simple to use? :mrgreen:
(With apologies to Tesral for nicking his sig. :mrgreen: )
Velutinous Vice Admiral
Re: Clear resin casting recommendation
Postby Tesral » Sun Dec 31, 2017 5:38 pm
I believe the issue with the clear resin is one of off gassing, Further research is required.
Rampaging Rear Admiral (LH)
Postby MEATLOAFr » Sun Dec 31, 2017 5:42 pm
for clear casts:
Warm the mold
Warm the resin - it will pour better, and bubbles will move out better
Use mold release
Vacuum chamber - to remove air bubbles
Pressure-pot - to make any bubbles that form tiny
expect first few cast to be junk, use them to learn what not to do on the next one
Postby MEATLOAFr » Sun Dec 31, 2017 5:43 pm
Tesral wrote:I believe the issue with the clear resin is one of off gassing, Further research is required.
yes, they can smell worse than standard resins, they also take longer to cure - best to leave them for a solid 24 hours before removing from molds
MadManMUC
Postby MadManMUC » Mon Jan 01, 2018 12:28 am
Thanks, lads.
I was after more of a clear resin brand recommendation to use with the Oomoo 30 moulds, though ... ;)
Postby MEATLOAFr » Mon Jan 01, 2018 12:54 am
MadManMUC wrote:Thanks, lads.
I haven't used that brand before, but if you have a small item done up - do a test with a small batch of the clear
Kratok
Perhaps today IS a good day to model
Postby Kratok » Wed Jan 03, 2018 3:10 am
I've been tempted to try this myself, and held off for exactly the same reasons you have. The warnings about the SmoothOn clear resins gave me second thoughts.
I've never got around to doing it, but was moving in the direction of trying some of the clear acrylic resins that they sell for encapsulating items in desktop paperweights. They are water thin, pour easily, and dry crystal clear and HARD (a lot of "clear" parts in kits that I have received remained a little gummy). They do not carry the industrial warnings like the SmoothOn clears. They are readily available (or at least used to be) at craft stores, and are comparatively cheap. I would bet they are compatible with Oomoo silicones. I dont know how they might react with tints, but you could easily post tint them with a quick airbrushing with one of the Tamiya transparent colors.
Again, I have never gotten around to actually doing this, and it is not exactly what you asked for, but it might provide an option that you could play with. If you do so, let us know how it works out?
MadManMUC
Postby MadManMUC » Wed Jan 03, 2018 10:13 am
I got the idea of using Oomoo from a couple of YouTube vids by Kenny Conklin at SciFiantasy, where he was using it to cast a solid (not clear) part for the Vor'Cha-class cruiser. He made it look actually pretty simple, so I thought it would be a good starting point for clear parts. But, like I said, SmoothOn's chemical badness for their clear resin is a bit of a turn-off for me.
Think I'll hit one of the big local craft shops here in Munich over the weekend to see what solutions they offer, and I'll report back.
Postby Tesral » Wed Jan 03, 2018 12:59 pm
Kratok wrote:I've never got around to doing it, but was moving in the direction of trying some of the clear acrylic resins that they sell for encapsulating items in desktop paperweights.
It is an acrylic resin not an urethane resin. That would be my only concern. Post casting handling.
Kratok
Postby Kratok » Wed Jan 03, 2018 8:46 pm
Agreed.
Like I said, I’ve never actually gotten around to trying this, so can’t guarantee it would work. But it would be a low cost, low toxicity option. Might be worth playing around with it and finding out.
Good luck!
Return to “Customizing”
Users browsing this forum: No registered users and 14 guests
