And now, a fibre optics question
LEDs, fiber optics, etc - everything needed to "Make it Glow"
MadManMUC
Postby MadManMUC » Tue Nov 14, 2017 10:54 am
Hey chaps,
So I learned this week (the hard/inconvenient way) that CA glue and fibre optics are not best friends, by any stretch of the imagination.
Can FO be glued in place with regular model glue (I've got the Revell Contacta stuff), or will I need to pony up for a hot glue gun?
Edit/Update
Well, after a quick test, the answer is an unequivocal 'no' to Revell Contacta. It didn't take long for the FO test strand to go snappy-snappy. :evil:
(With apologies to Tesral for nicking his sig. :mrgreen: )
Re: And now, a fibre optics question
Postby mophius » Tue Nov 14, 2017 1:11 pm
Hot is the only way to go for FO.
If you are quick and good you can slightly bend the FO while the glue is still warm to get it into shape for the LED. I have not managed this yet only snapping the FO causing more problems for later and having to remove the glue and broken FO.
Postby trekriffic » Tue Nov 14, 2017 3:38 pm
Hot glue works like mophius said. Also two part epoxy. White glue will work too but it takes a while to dry.
Postby MSgtUSAFRet » Thu Nov 16, 2017 1:42 pm
MadManMUC,
Another alternative for attaching fiber optic strands to an LED is UV light cured acrylic.
Here is a link from Walmart to give you an idea of what I am talking about.
https://www.walmart.com/ip/Lazer-Bond-R ... e/49528413
Here is another link: https://www.neweasy.com/product/5-secon ... 7GEALw_wcB
I haven't personally used it yet (I have a Republic Star Destroyer that needs fiber), but the theory of it looks promising and inexpensive.
Keeping you informed,
Postby trekriffic » Thu Nov 16, 2017 4:26 pm
MSgtUSAFRet wrote:Another alternative for attaching fiber optic strands to an LED is UV light cured acrylic.
Interesting. I wonder if it would work for making windows?
MadManMUC
Postby MadManMUC » Sun Nov 19, 2017 10:42 am
Thanks, chaps!
Might’ve been a bit of confusion, though: I was asking about attaching FO to Styrene. :mrgreen: I ended up going with hot glue, that sorted me.
Return to “Lighting”
Users browsing this forum: No registered users and 4 guests
