50x50=2500, 2 (pic heavy)
Postby slawton » Wed Sep 20, 2017 4:04 pm
50 Years, 50 (more) Models, 2500 Scale... Round 2!
Federation Starships:
    Enterprise NX
    Enterprise (TMP Refit) x2
    Enterprise (TWOK Damaged Refit)
    Enterprise (A)
    Enterprise (A Self Destruct)
    Excelsior Refit
    Ambassador
    Galaxy
    Galaxy (Saucer Separation)
    Galaxy (All Good Things)
    Sovereign
    Sovereign
    Defiant x2
    Miranda (Reliant) x2
    Miranda (Reliant - Damaged)
    Miranda (Reliant - Rollbar => Lantree - variant)
    Saratoga
    Federation Hermes Scout/Saladin Destroyer - saucer with single nacelle underneath
    Federation Anton - FASA / Reliant predecessor
    Federation Larson - FASA / saucer with single nacelle on top & additional rectangular primary hull
    Federation Locknar - FASA / saucer with dual nacelle above
    Federation Derf - FASA / similar to Locknar with extended bay underneath saucer
    Federation Dreadnaught - triple nacelle
    Enterprise (Jenghiz)
    Enterprise (Wilkerson)
    Enterprise (Kiev)
    Excelsior Un-Refit
    Premonition (modified Sovereign class)
    Soyuz
Klingons & other Aliens:
    Klingon D7M Ktinga x4 ( 1 as TUD Ktinga Quo'nos One)
    Klingon K'Vort x4
    Romulan D7 Battlecruiser: Command/Flagship
    Romulan D7 :The Enterprise Incident": Escort
    Cardassian Galor x4
Other:
    "Speed Racer" Mach 5
Subject to Change, Remainder To Be Announced
Legend / Color Guide
Red: Not Started, Missing Some/All to Complete
Orange: Either Not Started & Have Everything or Started but Missing Some
Yellow: In Progress
Yellow/Green: Assembled
Green: Cleaned & Primed
Green/Blue: Painted
Bluish: Finished (Decaled & Weathered if applicable)
Blue: Posted
I'm a doctor, not a modeler ...
Re: 50x50=2500, Round 2 (pic heavy)
Postby slawton » Wed Sep 20, 2017 4:05 pm
Last year Star Trek turned 50, so I tried the half-baked idea to do 50 TOS models in 2500 scale to celebrate (didn't quite make it, but still plan to follow through).
So I'll be turning 50 soon (was I conceived during a Star Trek Episode - could explain a lot!) so I need to use up what's left of my mojo (before going to the old folks home) and decided to double down. Essentially, I'll be working through my Round 2/AMT kits OOB, kitbashed, etc.
I'm kicking this off early to get some finished in time to give them to my brother for Christmas (possibly as early as Thanksgiving). He's a fan but not a modeler. It will also give me a good dry-run for when I attempt my "masterpiece" versions.
Postby el gato » Wed Sep 20, 2017 4:36 pm
Go slawton!
But can you count those that you built last year in your new effort? You did build them
Postby slawton » Wed Sep 20, 2017 5:08 pm
I don't intend to "double-dip", but any spill-over (>50) not included in final tally of the previous one is fair game.
Postby mophius » Wed Sep 20, 2017 5:14 pm
Can't wait to see some of these
Postby el gato » Wed Sep 20, 2017 5:25 pm
If past is prologue, there is good reason to look forward to the eye candy. Check out slawton's previous effort.
Rampaging Rear Admiral (LH)
Postby MEATLOAFr » Fri Sep 22, 2017 1:47 am
Let me know if you need decals again for these
I look forward to seeing more of your work
asmcelhinney
Postby asmcelhinney » Fri Sep 22, 2017 12:32 pm
Damn.
Looking forward to this playing out!
My fledgling YouTube channel:
Postby slawton » Fri Sep 22, 2017 2:53 pm
Well Hurricane Irma threw in a curveball, but life is returning to normal so hopefully some progress over the upcoming weekend. As I suspect with many of you, I've been more of a model kit "collector" than a model kit "builder" - so I'm trying to change that. Hopefully life has settled down a bit and I can have some "me" time (also the family does not want to hang out with me when I'm watching football - American that is). I have multiples of many these kits, so the first build will be more of a learning experience and will not stifle me with over "analysis is paralysis" keeping me from starting/finishing.
I'd also like to document the build to include ship/model specifications, other reference builds, etc. So I will put a post for each kit, then periodically update that specific post (rather than keep appending to the end of the thread). In this way, it could be used as a starting point for others. Any build threads of these 1/2500 Round 2/AMT kits or other scales you'd like to recommend, just PM me links so I can include them in my posts.
Postby slawton » Mon Sep 25, 2017 12:17 am
Getting started after a hiatus - as to be expected several of the glues were unusable (completely hardened). I thought I'd get started with something easy. Some of the original bases I intend to use as artwork instead. The duplicate base I'm using additional posts (cut shorter) to make it more of a star shape.
I've gotten a start with the assembly - the older kits have more issues (gaps, seams, holes, inaccuracies, etc.) that need additional work. The newer kits fit better with minor seems corrected with a little sanding. I might try building some without painting to see how they turn out. I hoped the phaser posts from the Lantree-variant Reliant could be used on the top of the saucer for the "All Good Things" Enterprise, but the posts are slanted rather than straight. The saucer-separated engineering hull has a heavy resin piece (from VA Miniatures) that I'm trying to adequately secure to the hull.
Users browsing this forum: No registered users and 35 guests
