This is a kitbash of a Coventry-class frigate. I'm using a Modular Models Coventry hull that I picked up in a trade with a good friend. I'm using UGH! Models Endeavor Type Nacelles. I'm calling them LN-52 Mk II units, based off of the LN-52 "Fastwing" nacelles for the Endeavour-class seen in Ships of the Star Fleet, Volume One".
I chose the name, Socorro, NCC1231, from the list of Coventry-class ships. I also chose it because it's town very near where the Karl G. Jansky Very Large Array is located, some 50 miles outside Socorro. The VLA has been featured in many TV Shows and films over the years and is indeed a really kewel thing to see - not that you can really see much of it from the road.
As of this writing, construction is mostly complete. Some clean up definitely needs to be done. I decided to add a TMP Refit bridge, first from a Polar Lights / Round2, the I went with an UGH! Models Refit bridge from their Lynch-class light cruiser, in place of the standard TOS bridge. My thinking is to show her most recent refit, which was done at around the same time as ST:TMP took place. Many internal systems were upgraded, tho other than the bridge, pennants/markings, and paintjob, she's the same, externally.
Taking a cue from the Reliant, I added that little flat-topped triangle. It's some thin Evergreen sheet stock pulled from a scrounge pile, so not sure what thickness it is, tho think it's maybe .020"?
Adding this piece to the bottom, which was included as what I guess was meant to be an extended engineering deck? Anyhow, adding it the ventral surface to act as an extended engineering deck.
These surface bubbles on the leading edge have been filled, sanded, filled, sanded, primed, filled... while I've seen much worse, this is still kind of disappointing. Buuuut, at least I have the hull to work with and didn't have to take a year or longer to get!
I also discovered that, while really well done, the extended hull isn't 100% squared off. Not a problem, as I adjusted for it. It just throws the "balance" of the placement of the pylons and nacelles of noticeably.
More to come.
USS Socorro, NCC-1231
- Griffworks
- Can-Do Captain
- el gato
- Fatidical Fleet Admiral
Re: USS Socorro, NCC-1231
I think I see it, now that you mentioned it. Regardless, this is a kewel build & am looking forward to more updatesGriffworks wrote:I also discovered that, while really well done, the extended hull isn't 100% squared off. Not a problem, as I adjusted for it. It just throws the "balance" of the placement of the pylons and nacelles of noticeably.
- Griffworks
- Can-Do Captain
Showing more work.
Pylons attached and puttying started. Nacelles not yet attached.
Nacelles and bridge attached. More putty and sanding done. This bridge is from a PL/R2 Refit kit. It was cut off of a kit to which it was previously attached. I didn't like how it looked, so I removed it and replaced it with a bridge from UGH! Models
Outboard view.
Showing off some extra artistic licensing I took during construction. I also love those oversized shuttle bay doors.
And a port view showing the mostly finished Socorro.
The UGH! Models bridge from their Lynch-class light cruiser.
More to come.
Outboard view.
More to come.
- Griffworks
- Can-Do Captain
After prodigious amounts of the primer, putty, sanding, and several repeats, I finally got those surface bubbles taken care of. I used Tamiya rattle can Surface Primer For Plastic & Metal (Gray). I've decided to use Tamiya rattlecan AS-20 Insignia White (US Navy) as the base coat, as I did with my USS Endeavour, NCC-1716, build.
I hand drilled Awalt Photon Torpedo Tubes into the B/C Deck, as per similar locations in both the Star Fleet Technical Manual and Ships of the Star Fleet, Volume One. I also drilled a single aft tube into the ventral extended engineering decks I added. Still trying to decide if I'll add physical Phaser emitters or just represent them with decals. If I go that route, I might add physical Phaser emitters over the top of the decals.
First full coat of primer.
Primed, note the Awalt photorp tubes in the forward B/C deck.
Aft view, showing the need for puttying several areas.
The stand shown here uses one of around 10 Star Fleet emblem bases that I received in a trade from a good friend, Larry. The piece supporting the model is a piece of brass rod from a clothes hanger.
Base coat - AS-20, Insignia White (US Navy) - applied to the leading edge and part of the upper hull.
Showing the base coat up next to the one applied to Endeavour, NCC-1716.
More to come, obviously.
- trekriffic
- Admiral of the Fleet
Good work. A lot of effort going into this but that only serves to make the final result all the more satisfying.
- Kratok
- Perhaps today IS a good day to model
Looks great, Jeff.
I like the idea of an interim upgrade, and she loos really nice with the Endeavor nacelles. I know this was one that you were wanting to build, and I am glad you finally got the chance.
- Griffworks
- Can-Do Captain
Hey, fellas! Thanks! And apologies for not responding sooner. I had intended to, tho you know what they say about intentions and a path to a certain place....
And thank you in particular, Kratok! I definitely appreciate you giving me the opportunity to have this to build. You rawk!
Update!
I've gone ahead and used Tamiya rattlecan AS-20 Insignia White (US Navy) as the base coat for Socorro - as I did with my USS Endeavour, NCC-1716, build. This gives at least two ships - and possibly a third to come - in the same paint scheme, showing some congruity for a certain timeframe in StarFleet history.
Beauty shot.
Aft view, showing the single aft tube. I'm kinda not a fan of the way-large hangar doors, tho at the same time I don't hate them.
I like this view. One you don't see very often with these style ships.
Rub muh belly!
Update!
Beauty shot.
Rub muh belly!
- Tesral
- Administrator
- Contact:
The ship is a cat!
I love the build. I like starships as unique objects.
- el gato
I like it a lot! There are several elements that I'll end up "borrowing"
