Dreadnought USS Abaddon -Finished Pics and Video!
Postby trekriffic » Sat Apr 02, 2016 7:28 pm
Ok. For my contest entry I've settled on bashing together something like this...
... an TOS era dreadnaught. I've been thinking of doing one for years so this should be fun!
Among other things I'll be using two 1/1000 scale TOS Enterprise kits.
Here they are with a copy of the local paper dated April 1:
My initial inclination is to make my build into a variation of the dreadnought; there are a few things I think can be done a little differently to make it more uniquely mine.
Stay tuned folks!
Re: Dreadnaught
Postby Moongrim » Sat Apr 02, 2016 10:47 pm
That looks intriguing.
Will you be utilizing the Federation Models Conversion kit for same?
Re: Dreadnaught
Postby slawton » Sun Apr 03, 2016 12:19 am
I was considering doing something similar. I think I saw a different image where the top of the saucer was more stair-stepped than smooth.
I'm a doctor, not a modeler ...
Re: Dreadnaught
Postby Kremin » Sun Apr 03, 2016 10:14 am
Very cool I always wanted a refit dreadnaught, just so much work
Re: Dreadnaught
Postby Moongrim » Sun Apr 03, 2016 11:17 pm
A refit dreadnaught?
Which version?
Federation *Uprated?
Or Ascension?
Re: Dreadnaught
Postby Kremin » Sun Apr 03, 2016 11:46 pm
Moongrim wrote:A refit dreadnaught?
Which version?
Or Ascension?
Federation Class, Ascension would be too much work in 1/350
Julien
Re: Dreadnaught
Postby Julien » Mon Apr 04, 2016 4:06 pm
Nice ! I look forward to it !
Re: Dreadnaught
Postby trekriffic » Thu Apr 14, 2016 11:57 pm
So made some progress last weekend and a few evenings this week. This ship will have a double thick saucer and beefier secondary hull with extra thick nacelle struts to support its three warp nacelles. It will feature a mega-phaser and photon torpedo ports fore and aft. It will be a real beast, nothing frilly just a true battleship capable of taking and dishing out severe punishment. More massive than the Federation Class, this is the proto-type of the Goliath Class Super Dreadnaught...
Double thick saucer test fit. I'll be using two lower saucer halves for this:
ImageTest Fit of Lower Saucer Halves by trekriffic, on Flickr
Using identical halves required trimming locator pins on one half and gluing tubing onto the stubs for the pins in the other half to slide into:
ImageEvergreen Tubing by trekriffic, on Flickr
To broaden the secondary hull I cut two sections of .040 styrene sheet to mostly match the profile of the secondary hull with exception of the undercut in the stern which this design won't have. It will actually be more cylindrical and somewhat longer than the unmodified secondary hull:
Image40 mil Styrene Sheet by trekriffic, on Flickr
The kit part's locator pins slide thru holes drilled in the .040 styrene sheet:
ImageTest Fit by trekriffic, on Flickr
I cut out a slot to accommodate a short length of Evergreen tubing for the brass display rod I'll be using to slide into:
ImageSlot for Mounting Tube by trekriffic, on Flickr
The nacelle pylons would later be removed and thickened using brass strip. The angle would be lowered to 30 degrees from the horizontal as well:
ImageSecondary Hull Glued and Clamped by trekriffic, on Flickr
Took this photo before I redid the pylons:
ImageSecondary Hull on Display Rod by trekriffic, on Flickr
I'm toying with the idea of attaching the upper hull B-C deck from the kit to the lower saucer and making it into some kind of mega-phaser/photon torpedo housing:
ImageUpper B-C Deck Repurposing by trekriffic, on Flickr
Everything seems to fit together really well up to this point. I had to widen the slot in the lower saucer though to fit the thicker dorsal:
ImageTest Fit with Saucer by trekriffic, on Flickr
Working off some schematics of the TOS three engine dreadnaught on the internet I determined that the two lower nacelle pylons on the secondary hull were at a 30 degree angle from the horizontal. I bent a narrow piece of brass strip to that angle on each end and sandwhiched it between the upper and lower kit pylons halves, gluing it together as one assembly using CA glue:
ImageTemplate for New Nacelle Pylon Angle by trekriffic, on Flickr
Two holes were drilled thru the center section of the brass strip to allow for pins to be inserted thru it and into the secondary hull for added strength:
ImageHoles Drilled in Brass by trekriffic, on Flickr
This turned out really well and the pylons are very rigid and sturdy with the brass reinforcement. The struts will actually get 50% wider and possibly a little shorter before I'm finished with them though:
ImageNacelle Pylons Glued into Strongback by trekriffic, on Flickr
That's all for now. More to come!
Re: Super Dreadnaught -Pike Era
Postby DefiantClient » Fri Apr 15, 2016 12:32 am
I love the idea of the weapon pod on the bottom of the saucer. Great job thickening up the hulls. Are you going keep the saucer edge like that or are you planning on beveling it to only be at one angle? I personally like it the way it is.
Postby Drop_Bear » Fri Apr 15, 2016 2:22 am
Say! This is a really neat concept. We need more love for the concept of Federation warships. Sun Tzu (or maybe it was someone named Bob) told us to "pray for endles peace, but prepare for eternal war", not "pray for endless peace, and stick your fingers in your ears and pretend war does not exist".
Users browsing this forum: No registered users and 13 guests
