USS Constitution - 1/2500 scale (Finished)
Postby DefiantClient » Fri Apr 01, 2016 2:36 pm
Sort of a placeholder post for now, but I'm planning on building a 1/2500 USS Constitution based off the pilot USS Enterprise. It will be based on the second pilot Enterprise because I'm not a fan of the endcaps of the original pilot's nacelles. I'll be posting the starter WIP picture tonight, but for now here's some pictures of the pilot Enterprise, which I'm hoping my model will look pretty close to.
So yeah, that's what I'm going to be shooting for. 8-)
Re: USS Constitution - 1/2500 scale
Postby slawton » Fri Apr 01, 2016 3:27 pm
Hey DC-minor note ("picking nits").. The second image is of the 1st pilot Enterprise (the rest are of the 2nd pilot but I believe the impulse engine rectangles should be lighter gray on the bottom pick). While physically shaped the same, the 1st pilot has no lights (they are all painted on). Also, the front of the bridge appears different (there is a large rectangular window on the 2nd pilot). At some point I'll post pictures showing the differences between the various Enterprises into my contest build area.
I'm a doctor, not a modeler ...
Postby DefiantClient » Fri Apr 01, 2016 4:02 pm
Ah. good to know. The overall shape of the parts are the same though, no? That's more of what I'm going for. Thanks for pointing it out, but just so you're aware, the final product will not be accurate by any stretch of the imagination. I don't like the big light on the front of the second pilot bridge, so I'll incorporate the plain old front of the 1st pilot bridge in there. That was actually my original plan. :lol:
I have the PNT 1/2500 decals, so I should be good with the impulse engines' look. PNT also included a lot of neat TOS and pilot TOS stuff on a detail decal sheet, so I'll be using a bit of those as well.
Postby trekriffic » Fri Apr 01, 2016 5:32 pm
Nice choice of subject! I don't think I've ever seen build of either of the pilot ships in the sacred scale.
Postby DefiantClient » Fri Apr 01, 2016 6:33 pm
trekriffic wrote:Nice choice of subject! I don't think I've ever seen build of either of the pilot ships in the sacred scale.
In a way that's why I decided tackle this, even before the contest. I've never seen anyone do it before. I'm guessing it's because the model needs so much work to get it right. I don't care a ton about getting it accurate so I guess that's also a plus for getting something done.
Does anyone have any ideas for getting the antennas on the tips of the bussard collectors? I'm thinking REALLY thin paperclips, but if there's something out there I don't know about, I'd love to hear about it.
Postby trekriffic » Fri Apr 01, 2016 6:43 pm
DefiantClient wrote:Does anyone have any ideas for getting the antennas on the tips of the bussard collectors? I'm thinking REALLY thin paperclips, but if there's something out there I don't know about, I'd love to hear about it.
Paper clips would be too thick. I'd use piano wire which is made of steel and is very strong. You can get it in really fine sizes from your local hobby store, it's used in RC airplanes to operate the rudders and flaps. Alternatively you can buy a size 80 drill bit and break it in half to make two shafts. Now making the collar for the base of the spikes and the little knobby thing for the tips is a whole 'nuther challenge.
Postby DefiantClient » Fri Apr 01, 2016 7:53 pm
I have some fairly thin paperclips I use to pin my Warhammer miniatures' arms, but you may be correct and even those might be too thick. My local hobby store definitely doesn't carry piano wire. :lol: There's probably an out of the way mom and pop that sells RC stuff, but I don't even know the first place to look. I think I have a thin guitar chord I can uncoil and use the center of that which may be thinner than paperclips.
I'm not modeling the nubs. They'd be too small to notice anyway. I'm not a Scotty-like miracle worker, unfortunately. :(
Postby trekriffic » Fri Apr 01, 2016 11:13 pm
DefiantClient wrote:I'm not modeling the nubs. They'd be too small to notice anyway. I'm not a Scotty-like miracle worker, unfortunately. :(
You sure? All you need is some small round stock in your dremel's chuck. Spin it like a lathe and use files and sanding sticks to make that conical/knob shape. Do the same to make the cone for the base. It's delicate work but it could be done.
Postby Drop_Bear » Fri Apr 01, 2016 11:30 pm
A Second Pilot styled USS Constitution? Sweet!
Postby Kremin » Sat Apr 02, 2016 12:10 am
How thin are the pins used to fasten model railway sleepers, wonder if they would work?
