Kremin's big build USS Revere NCC - 595 1/350 Scale (Finished ... for now)
Re: Kremin's big build USS Revere NCC - 595 1/350 Scale
Postby Kremin » Fri Jun 24, 2016 6:33 pm
First test fit
Slight adjustment and it'll be fine
then fill in most of the windows, other than the Chief's office and work out where to add the Nacelle vents
Postby NCC1966 » Fri Jun 24, 2016 8:03 pm
THIS is going to be A build!
:shock:
Postby Kremin » Fri Aug 19, 2016 10:00 am
Finally got some paint for the two projects everything is primed and started on the top coat
Gave the shuttle it's cabin light
filled the windows in on the lower pylon, other than the Chief engineers office
Postby DefiantClient » Fri Aug 19, 2016 3:42 pm
Looking good!
Postby Kremin » Tue Aug 23, 2016 4:58 pm
Iwas originally going to mount the ship at the bottom of the nacelle, but the ballance point was too far forward so I had to move it into the main hull
hopefully used enough putty to keep it secure
put a bolt through the upper hull to act as a securing post to the upper neck after the neck is sealed I'll pour some epoxy to flood the bottom and secure it properly to the main hull
Postby Kremin » Tue Aug 23, 2016 7:29 pm
Finally able to try the major components together to get a feel for how the final design will look
Lots of trimming, adjusting, detailing, lighting and decals / registration to go but big milestone today seeing it like this
Julien
Postby Julien » Wed Aug 24, 2016 6:17 am
Looks great ! Nice kit bashing !
Postby Kremin » Wed Aug 24, 2016 11:03 am
Time to grab some computer time and sort registry markings
After I did a test sheet I added Revere's badge
First try with card looks good so I can do it with the frisket paper
Postby Kremin » Wed Aug 24, 2016 4:01 pm
Masked and ready for spraying
Postby Moongrim » Wed Aug 24, 2016 4:11 pm
She's starting to come together.
Users browsing this forum: No registered users and 13 guests
