Ideas & Projects for Federation Ships
dJiPi
Re: Ideas & Projects for Federation Ships
Postby dJiPi » Mon Dec 12, 2016 11:11 am
Bottom view:
Bottom view
You can see the "secondary" hull (Galaxy after cutting the aft part/pylons for a Nebula project) and the 2 pieces from a Ent-B secondary hull aft section: I will try to fit these pieces (and a sheet of styrene in between) for the aft phasers and torpedoes launcher.
dJiPi the froggy
dJiPi
Postby dJiPi » Mon Dec 12, 2016 11:16 am
Something like that:
Aft phasers
... more or less !
dJiPi the froggy
dJiPi
Postby dJiPi » Mon Dec 12, 2016 11:43 am
Did you notice that the curvature of the bussard collectors almost match the leading edge of the Sovereign saucer ? The forward centering pins are in perfect position as well:
Warp saucer
The Dreadnought is supposed to have multi-vectors attack capabilities so the saucer will get its own warp nacelles. The aft of the nacelles will be shortened so they don't extend out of the saucer, the rectangular opening (where it was supposed to connect to the pylons) will receive additional blue cooling grids).
dJiPi the froggy
dJiPi
Postby dJiPi » Mon Dec 12, 2016 1:32 pm
Today is a good day:
just arrived
... brought by the postman :D
dJiPi the froggy
dJiPi
Postby dJiPi » Tue Dec 13, 2016 2:39 pm
another WIP: the Supernova class attack cruiser
I will have to shorten the secondary hull by removing the center section. Thus the pylons will be closer to the saucer. Warp nacelles expected: MVM 505 (something else to order .... :oops: ). I will also remove the Captain's yatch.
The saucer is an OS Norway saucer.
dJiPi the froggy
dJiPi
Postby dJiPi » Thu Dec 15, 2016 4:09 pm
Oups, I did it :mrgreen:
Edit: just finished to remove the yacht from the sensor trench (without damaging everything around), now need to assemble the nose but, of course, the halves don't match perfectly, everything is warped :pullinghair:
dJiPi the froggy
dJiPi
Postby dJiPi » Fri Dec 16, 2016 11:51 am
so many projects (and my putty is too much old)
I tried to mix some glue with the putty but, strangely, it makes it less adhesive so when I remove the masking tape, it peels off (see the Galaxy saucer).
Now I directly apply the putty, then I drop some glue on top to shape it a little bit before sanding.
dJiPi the froggy
dJiPi
Postby dJiPi » Tue Dec 20, 2016 11:10 am
almost completed the Kelvin like ship, just a little bit putty and sanding jobs remaining:
you can also see the shortened Sovereign secondary hull in progress
dJiPi the froggy
dJiPi
Postby dJiPi » Tue Dec 20, 2016 11:13 am
something else, could somebody identify this ship please (scale/name/class/designer/maker) ?
I really like this uncommon design.
EDIT: ok, it's the Douglass, thanks Del, unfortunately in 1/1400 scale, but who knows ? if re-issued maybe a multi-scale version with 1/2500 decals is possible ? :drool:
dJiPi the froggy
dJiPi
Postby dJiPi » Wed Dec 21, 2016 9:53 am
For those who would like to shorten the Sovereign secondary hull (WIP):
it could almost be a ship on its own !
dJiPi the froggy
Return to “Customizing”
Users browsing this forum: No registered users and 9 guests
