Aztek Dummy Question
scaddude
Postby scaddude » Thu Mar 30, 2017 11:28 pm
After all these years, I've finally decided to give aztec templates a try. I just found a video from 4 years ago warning about the incredible stickiness of Aztek Dummy. So, I was curious: Is this still the case? Have they improved or should I move on? I was looking at their sets for all the Enterprise, B, Excelsior, Reliant, NX, and JJ-Prise.
Thoughts? I know Orbital Drydock has a set as well, but not for the same ones.
"If nothing we do matters, all that matters is what we do..."
Julien
Re: Aztek Dummy Question
Postby Julien » Sun Apr 02, 2017 8:38 am
Hi,
Yep, nowadays Lou (aka AztekDummy) uses yellow vinyl which is a lot less sticky than what he was using before.
Basically, the masks are black, be careful as they are the older version, but if they are yellow is all good.
Still, be careful using them, let the paint cure completely and do a quick gloss coat before using the masks.
Postby Moongrim » Sun Apr 02, 2017 4:37 pm
Julien wrote:Hi,
Good advice.
When removing said masks- be VERY patient. I use a NEW X-acto blade (with handle) to ccccaaareefully nudge up a corner of the mask and gently tug it up off of the model with a set of fine point tweezers. Be sure to keep a set of bottles containing the pigments you're using for touch ups.
scaddude
Postby scaddude » Mon Apr 03, 2017 6:39 am
Thanks gang! Good to know.
Rampaging Rear Admiral (LH)
Postby MEATLOAFr » Tue Apr 04, 2017 1:49 am
scaddude wrote:Thanks gang! Good to know.
yes, we spread the knowledge like the smell of a dead skunk on the road (you make not know where it's coming from, but you know it when you smell it) :lol:
Users browsing this forum: No registered users and 13 guests
